TN 95 EG Coupe, LSV-T BUILT! Laskey,Pro1,Precision,ID,Victorx,LSD
Old Oct 22, 2012 | 03:53 PM
TeggieeTuner's Avatar
Default 95 EG Coupe, LSV-T BUILT! Laskey,Pro1,Precision,ID,Victorx,LSD
For sale is my 95 civic that I recently built over the last month since I’ve been home from deployment. I bought the car a few years ago with a d series in it and drove it daily for awhile. When I got deployed I had my mind set on building a racecar that I could legally drive on the street. I am active duty and bought a house a few weeks ago and have no furniture and that is my reason for selling the car, its time to get out of the game for a little while and furnish my house.
I ran out of leave days and had to come back to base before the car was 100% complete.
It needs VERY minor things that I will be completely upfront and honest about.
*The paint on the roof and trunk is faded.
*The inner gator axle on the drivers side has a small tear and leaks some grease.
* I think the coil in the dizzy went out so I bought the msd “blaster” kit( I used a friends dizzy to start/drive the car) The msd stuff also needs to be installed.
* Its throwing codes 14( IACV) and 1 due to no o2 sensor.
* The intercooler piping from go autoworks needs a little trimming ( it pushed the bottom of the intercooler out further than the top)
* The car needs a shift ****.
* THE Biggest issue after all that small stuff is fixed is that THE CAR NEEDS A TUNE!!! This whole build has less than 20 miles!!!
It will start with stock injectors stock map sensor and a stock ecu.
It will start with the GM 3 bar, ID 1000cc injectors, and chipped ecu with the phearable basemap, BUT it runs VERY rich!!
With that being said If you want to hear it run I will have to put stock injectors and injector clips back on.
Everything I mean EVERYTHING was purchased BRAND NEW, NOTHING second hand or ebay here except the intercooler and radiator.
I had the transmission, LSD, and turbo oil feel line(B & R fittings) from a previous build that was not purchased brand new but I did have the trans gone through and all synchros replaced and clearances checked on everything before I put it in this car.
The block and crank I purchased from laskey racing to save time and shipping costs.
Here is the good stuff:
95 Civic Dx
Clean title
Black interior
Wire tuck/ battery relocate
comes with slicks mounted on 14" wheels
Block: LASKEY BUILT
84mm Benson sleeved B18a1
Benson micro-polished crank
Pauter Rods
CP 9:5:1 pistons
ACL Race bearings
Oem Timing belt
Type R oil pump
LS waterpump
Moroso Oil pan
Every gasket/ O ring replaced with OEM
Innovative motormounts
Head:
Port mached Gsr head
Skunk2 Pro 1 cams
Skunk2 Pro springs/retainers
fresh resurface, valve stem seals
Edelbrock Victor x intake
Hondata IM gasket
Omni Power 70mm Throttle body
ARP Head Studs
T1 race development catch can kit (6 line kit) Black braided lines
AEM Cam gears
Golden Eagle 84mm Ls vtec kit
Turbo Kit:
King motorsports T3 Topmount + downpipe
Precision Sc61 .68 , .70 ported "s" Compressor
Precision 46mm wastegate
Tial 50mm BOV
Go autoworks 2.5" Intercooler piping kit
HUGE front mount with 3" inlet and outlet
Fuel:
ID 1000cc injectors
Walbro 400lph pump
Aem Fuel rail
Fuel Lab FPR ( not installed)
Fuel lab inline fuel filter
Ignition:
Oem dizzy
Msd cap/rotor plug wires
Blaster 2 coil (not installed)
Trans:
9lb flywheel
ARP Flywheel bolts
Competition Clutch Stage 5 unsprung with Upgraded Pressure plate
ATI Race Damper
Stock Gsr trans with Type R helical LSD
Gator Axles
Brakes:
Brembo Blanks F/R
Hawk HP+ Pads F/R
Goodridge SS Lines F/R
Integra Rear disc swap ( ebrake not hooked up)
Tune:
Phearable basemap
Mac boost solenoid ( not installed)
GM 3 bar map sensor
Innovate MTX-L wideband
oil pressure gauge
coolant temp gauge ( not installed)
boost gauge
Wheels/Tires:
Function form coilovers
Kosei K1 15's
Brand new Falken 512 205/50/15
With a bigger turbo and a good tune this motor will yawn at 700whp…. Laskey is AMAZING!
I have WELL over 10k invested not including the price of the car.
My asking price is 8k firm!
Please do not lowball me or waste my time if you don’t have the cash.
NO TRADES!!!!! Unless its cash + Furniture
NOT PARTING THE CAR OUT!!!!
ONLY if you have the cash or form of payment will I have a few friends trailer the car to meet you.
I HIGHLY recommend you bring a trailer due to the car not being safe to drive with no tune.
No Pm's please, call or text. If i dont respond leave a voicemail.
Thanks for looking,
My name is Dustin
615-four four zero-2241
before the swap:
This is how the exterior looks minus the hood( car has no hood):
Engine/Build process: * Note car was still getting put together during most of these pics
How it runs with the phearable chip on the big injectors:
Old Oct 22, 2012 | 04:37 PM
Default Re: 95 EG Coupe, LSV-T BUILT! Laskey,Pro1,Precision,ID,Victorx,LSD
Please bump if you view
Old Oct 26, 2012 | 06:21 AM
Bump
Old Oct 26, 2012 | 06:26 AM
Wobbz's Avatar
Would pay you for a ride... She sounds MEAN!!! GLWS
Old Oct 26, 2012 | 02:03 PM
Thanks man!
Old Oct 27, 2012 | 08:05 AM
Bump if i dont respond Im out at sea... email : Dustin.ams@gmail.com
Old Oct 28, 2012 | 08:04 AM
671 Ryder's Avatar
nice EG
fullcircle
Appearance Build Threads
222
Dec 4, 2015 05:19 PM
eoris__ej1
Dec 16, 2009 10:28 PM
97accord_R
13
Oct 21, 2009 06:19 PM
TurboBumblBee
22
Apr 23, 2003 07:07 AM
