Toda Spec C question
Old Oct 17, 2002 | 07:37 PM
Turbo R's Avatar
Default Toda Spec C question
ive been here that these cams will make you lose compression.
true or false and why?
Old Oct 17, 2002 | 07:39 PM
uNF$@#!'s Avatar
Default Re: Toda Spec C question (NA ITR)
toda designed their spec C's with economy in mind. with the spec C's, youre compression will drop to about 16:1 and youre MPG will increase by atleast 20 mpg.
Old Oct 17, 2002 | 07:46 PM
sackdz's Avatar
Default Re: Toda Spec C question (Soup ****)
Yes, you will lose some dynamic compression because the duration is longer. Meaning the cam profile is such that the intake valves will be open for a slightly longer period of time at the beginning of the compression stroke, lowering compression a slight amount.
Old Oct 17, 2002 | 09:52 PM
mafay2's Avatar
New User
Default Re: Toda Spec C question (sackdz)
And that is why you need to run higher compression to get more power out of the spec C
Old Oct 17, 2002 | 09:55 PM
Reid's Avatar
Global Moderator
Why even make a post if you don't know the answer?
Spec C's lose dynamic compression like Ed said.
Old Oct 17, 2002 | 10:07 PM
Mr.Integra's Avatar
Default Re: Toda Spec C question (Reid)
shh
he's trying to be cool
Old Oct 17, 2002 | 11:39 PM
Type-ARR's Avatar
gay......
Old Oct 18, 2002 | 01:12 AM
jdmrealm's Avatar
New User
Old Oct 18, 2002 | 01:27 AM
Drag R's Avatar
why do you even bother posting?
Old Oct 18, 2002 | 06:13 AM
Hooch'n's Avatar
Default Re: Toda Spec C question (Drag R)
Higher comp. is needed to have full potential of Higher diration cams "Spec C". Yes, your car will loose compression with these cams, that is why you run higher compression.
Old Oct 18, 2002 | 09:25 AM
Teepo's Avatar
Default Re: Toda Spec C question (Hooch at 8400-RPM)
So if your compression is lets say, 13:1 , at peak duration what will compression be? im just trying to decide between jun or toda. thanks
Old Oct 18, 2002 | 09:31 AM
JPP's Avatar
JPP
Default Re: Toda Spec C question (ITR1150)
Dynamic compression is not very easy to calculate. You need a bunch of dimensional information regarding the camshafts and engine block / head. However I know there is a dynamic compression calculator on a web site somewhere , I will try to get my hand on it.
Old Oct 18, 2002 | 11:38 AM
Tbone's Avatar
here you go.
http://www.team-integra.net/forum/di...PagePosition=1
Old Oct 23, 2002 | 02:10 AM
shadyCTR's Avatar
Default Re: Toda Spec C question (Tbone)
so what about the toda spec B's, will you lose compression with them also!
Old Oct 23, 2002 | 09:23 PM
Mr.Integra's Avatar
Default Re: Toda Spec C question (shadyCTR)
yes
Old Oct 23, 2002 | 09:45 PM
JDM nerbie's Avatar
New User
its called "valve overlap"
Old Oct 23, 2002 | 10:01 PM
Paste's Avatar
Loved
Default Re: Toda Spec C question (JDM nerbie)
with spec b's, if you just run a thinner headgasket, you should probably be Ok.
Old Oct 25, 2002 | 09:33 PM
threatcon13's Avatar
New User
He needs attention because his parents didn't give him any as a child. Obviously his post count has inflated his head somewhat.
Wannabe JDM
Jan 19, 2007 11:18 PM
Ger_Mugen_Civic
Nov 5, 2004 07:35 AM
MOTOR R
Apr 23, 2002 05:02 PM
blazin
Jan 6, 2002 07:31 PM
blazin
Dec 26, 2001 07:31 PM
