Stainless welding question..
Old Oct 22, 2012 | 07:48 AM
Smashback's Avatar
Default Stainless welding question..
I've done a decent bit of mild steel mig, but I'm about to tack up a 304 stainless exhaust and have some questions. It's easier for me to do the tacks with a mig, since that's what I have, and I can do it at the house then give the piping to my buddy to finish with the tig.
Basically I'm wondering if I use a mig with 308L wire just to tack it together using 75/25 gas will I get any real rust? I understand that the co2 will introduce carbon to the welds, but if it's just a few tack welds is it anything to worry about?
I'm a little OCD and I figure if I'm going to the trouble of doing everything in 304 (hangers in 409) then I don't want to eff it up and have rusty welds from the gas...
Old Oct 22, 2012 | 09:40 AM
sdr KEL's Avatar
Default Re: Stainless welding question..
use a sharpie, n mark it down where the pipe meets n give it to ur buddy like that
Old Oct 24, 2012 | 12:02 PM
h2.4's Avatar
use pure argon when tacking. The sharpie idea might work, but that seems like a lot of room for error by the time it is all welded together while not being on the car. I don't think it will fit good without having it tacked on the vehicle.
Old Oct 24, 2012 | 01:28 PM
Smashback's Avatar
You're right, it would be close, but even with pre-bent piping, I'm adding a muffler, resonator, a two bolt flange and a v-band. I'll need to have everything up on stands and in place to tack it to make sure it's right.
Additional bottles of gas are what I'm trying to avoid, I don't want to pay out for another tank and gas that I won't likely ever use again, or at least not for a long time.
I was just asking to see if I could make due with what I've got, but I'm going to see if I can just take it over there and do it there. No biggie I was just trying to go at my own pace instead of having to do all the cutting, trimming, welding, etc at once. Thanks guys
Old Oct 25, 2012 | 07:09 AM
h2.4's Avatar
You can't borrow the tig? When I do exhausts I still tack with the tig. If not You'll want to get a small bottle of argon, or borrow a bottle from the guy that is gonna tig it. I wouldn't wanna tig over someones non argon mig'd tack welds. But some people don't care about that stuff. whatever you're willing to let slide.
Old Oct 31, 2012 | 06:05 AM
that-guy's Avatar
should be no issue at all. most will grind down the tack to give a clean pass for the tig. lay a bead between tacks, grind the tacks, then proceed with another bead. this will also ensure a clean surface for the final tig welds
Old Nov 10, 2012 | 08:28 PM
zacheryleatherw's Avatar
The c25 gas won't rust the weld I've welded a entire stainless tank out that was 5'x5' inside and out with 308L wire and its still holding up today just make sure you don't use a flappy wheel that's been used on carbon steel or it will rust. The only thing is the weld will have a blackish color if not buffed and the c25 is better than using pure argon with the mig
Old Dec 7, 2012 | 09:43 PM
aroddpr's Avatar
I wouldn't worry about it, tac it with your mig and then have your buddy tig the rest, that's what I would do
Old Dec 11, 2012 | 11:18 AM
LOLZERSKAKES's Avatar
yeah. for exhausts because they are so thin tig welding works best. you can use mig but you have a better chance of burning through. Best bet, go with tig welding. looks more attractive and lesser chance of burning through. good for tacks tho.
- im a welder
akira712
Welding / Fabrication
17
Apr 2, 2007 12:32 AM
JDMCRX
Nov 26, 2006 05:43 PM
Flashmn
Oct 31, 2005 03:44 PM
yellowturbo
11
Mar 12, 2005 10:00 PM
GPoodle
Jan 13, 2004 03:06 PM
