Setting up suspension for the street
Old Oct 22, 2012 | 07:07 AM
LightningTeg's Avatar
Community Builder
Default Setting up suspension for the street
Starting to think serious about getting this car to hook high power on the street. I know it can, and I've seen it done a few times. I want to be that Honda that actually puts the power down without putting a ridiculous tire like an M&H 26" on it. I've thought about a 4.05 final but that's a different discussion.
Looking at Progress drag street/drag coil overs. Right now I am on Eibach pro kit springs and bilstein shocks. Car is just soft and squats to hard.
What are you guys doing for alignment settings up front?
The car is currently on 225/45/16 R888s and it does decent, but I want to hook full power in 3rd as well as 4th. I know it can do better with the right suspension. Its got full race bars and I plan on getting some good mounts (just have torque inserts now). I will get it corner balanced when I figure it all out as well.
Old Oct 22, 2012 | 07:58 AM
LS AzZkIkr's Avatar
Default Re: Setting up suspension for the street
Do you have a aftermarket suspension bushings? I would say that is just as good of an investment to putting power down as bars. I'm interested to see what others say as far as coil over setups.
Old Oct 22, 2012 | 08:32 AM
1320em1's Avatar
how do you have your bars set up pushing or pulling.
Old Oct 22, 2012 | 08:44 AM
4cylfiend's Avatar
Shut up Chris!!!
Old Oct 22, 2012 | 08:46 AM
Community Builder
Stock bushings. I have a set of lower control arm bushings for the front I will probably do this winter too. Just dreading it lol
Bars are pulling
Old Oct 22, 2012 | 08:50 AM
4cylfiend's Avatar
You would like my OmniPower coilover setup for the street. Its 10k front and 12k rear.
-Pulling your caster forward as much as possible with the trac bars, without F***ing stuff up will help too.
-Slightly negative camber in the front will help keep a full contact patch on the ground when your front suspension unloads (when the car raises)
-The "toe'd in" side of spec will help keep the car tracking in a straight line at speeds.
Old Oct 22, 2012 | 09:31 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
Should the rear end be lower or higher than the front?
Old Oct 22, 2012 | 09:52 AM
4cylfiend's Avatar
You want the back of the car to sit higher than the front to keep as much weight over the front of the car and minimize weight transfer to the rear. It also plays a role in aerodynamics.
ChillyWilly94
Dec 31, 2009 12:45 PM
a1320addict
Jul 21, 2006 01:27 PM
Mr.E.G.
Dec 6, 2005 04:30 AM
MikeTV
Aug 7, 2003 08:29 PM
G2Integrity
Jul 3, 2002 04:51 PM
