My 2.0 turbo build: Taking it Paso a Paso
97 Integra LS
I been working on this project for a long time already but never thought about making a build thread until now that i got convinced too by ( Monjarassi )
Specially now that i have alot of free time for now, well a little info about about the car, its an 97 integra that i traded my sister for my civic to sale. I started by just doing the basic bolt-ons n stuff just like everybody does to have a little fun here n there, later on i installed a NX nitrous kit system with the help of ( Monjarassi ) n had fun with that for a few months.. at the mean while i started getting turbo parts here n there because my goal was to go turbo. But then the bad thing happen i fried a piston n was put on the spot to rebuild the motor that i have or go all out, with the help of my bro-in-law i chose to go all out. So i took the motor out n started taking everything out. First off was cleaning out that engine bay because it looked sooo stupid (my opinion). Ive always wanted the 98-01 body style sooo i decided to start sourcing the parts for it and i also wanted to change the color of the car too PY. So i leave ya off with the pictures of the history of my project and up to date where it stands.. I will be updating as i go so bare with me.
Also the main reason to start this massive thread is to help me keep track of the beggining and end of my project racekar..
And for the onlookers and followers any addvice and help or contribution to my build would be helpfull and highly appreciated. Thanks in advance.
Block B18b
AEBS sleeves w/ copper o-rings
Manley Turbo Tuff LS Rods
84mm Manley 9:1 Pistons (polydyned on tops and skirts)
ARP main studs
micro polished LS crank
ACL race bearings
Type R oil pump
New water pump
Oil pan has 1/2'' pipe fitting welded on it for turbo drain w/ -10 AN fitting
Head:
Skunk2 pro 1 cams
STR intake mani
RPM 72mm throttle body
Twin Scroll custom top mount manifold
Super-Tech guides (bronzes)
Super-Tech black nitrate valves (dish)
Super-Tech dual valve springs n titanium retainers
Golden Eagle fuel rail
Tial 38mm waste gates
CX racing 3inch intercooler piping/black couplers
Full Race back door intercooler
Suspension & Brakes
KSport coilovers
Skunk2 lca
Comptech swaybar and Tie bar combo
Custom brake lines
ABS delete
Downstar Inc B.B delete
Willwood master cylinder
S2k CMC
92-95 civic Manual steering rack
5 lug hybrid conversion
BlackWorks extended studs (black)
BlackWorks open ended lugnuts (black)
BlackWorks rear camber kit
Cosmetics:
Full shaved bay
PY color change
VIS carbon fiber hood
98-01 front bumper
98-01 rear bumper
98-01 headlights
98-01 rear tail lights
Type R side skirts
Type R valances
Type R front lip
Type R spoiler
Missing items:
Turbocharger
Fuel Injectors
Downpipe
Dump tubes
Engine harness
Tial Blow off valve
Cam Gears
Transmission
Axles
Brakes
Fuel system
Golden eagle Vtec Full Conversion Kit
ARP head studs
I will start with the beginning of the history of the car, and slowly update it of all the stuff i have done..
Heres the car when i first got it.
And the first setup i started putting together..
And the day after i fried the piston..
Also the conversion took place and only snapped a photo of the rear that day
By that time i had pulled the trigger and sent the car to the body shop for the shave bay and color change
Also moved on to the hybrid 5 lug conversion, brake lines tuck, and manual steering rack.
Block B18b
ARP main studs
ACL race bearings
Type R oil pump
New water pump
Head:
Skunk2 pro 1 cams
STR intake mani
Suspension & Brakes
KSport coilovers
Skunk2 lca
Custom brake lines
ABS delete
S2k CMC
Cosmetics:
Full shaved bay
PY color change
98-01 front bumper
98-01 rear bumper
98-01 headlights
Type R side skirts
Type R valances
Type R front lip
Type R spoiler
Missing items:
Turbocharger
Fuel Injectors
Downpipe
Dump tubes
Engine harness
Tial Blow off valve
Cam Gears
Transmission
Axles
Brakes
Fuel system
ARP head studs
Looks like a great build thread! so you have no power steering? Like how you had the paint job done right! strip the car down bare! and shaved bay= sweet!
Okay fellas onto the next set of pics of my build..
In this batch of pics ya'll see pretty much all the performance parts for the build and couple of changes since my original plan for the turbo setup..
(btw im the bro in law thats contributing with the build)
What car is that steering rack from? I know there are a few Hondas that had them. Also did you have to swap the sub frame, or did it bolt to your existing one? Curious
Yup no power steering....n yea the rack came from a 92-95 civic...it'll bolt on strait in, but I had to use the bushing from the original power steering rack... the manual rack is smaller then the power steering one sooo you need to cut the bushing to make it work n stay in place ....
