lost motion assembly
Old Oct 17, 2002 | 07:19 PM
CivicEx95's Avatar
Default lost motion assembly
If I'm installing ITR cams and valvesprings into a GSR, do you need the LMAs too? And what exactly are the LMAs and what do they do?
Old Oct 17, 2002 | 09:14 PM
Rob Dizzle's Avatar
Default Re: lost motion assembly (CivicEx95)
yup you need them
your car will still work with the gsr ones it came with, but when I added itr cams I did them.
get them!
this should me moved to teg or tech forum...
Old Oct 17, 2002 | 09:46 PM
Pho Real's Avatar
Default Re: lost motion assembly (Bob-DC2)
dont lose them
Old Oct 17, 2002 | 09:48 PM
Reid's Avatar
Global Moderator
Default Re: lost motion assembly (VTEXTC HB)
dont lose them
Do you ever post useful information?
[Modified by Reid, 8:48 PM 10/17/2002]
Old Oct 23, 2002 | 12:24 PM
CivicEx95's Avatar
If my car will still work, what is the advantage to the R ones? What exactly do the LMAs do and why are they a needed upgraded?
Old Oct 23, 2002 | 12:28 PM
tonyxcom's Avatar
The Type R ones are stiffer. The Vtec rocker uses it as a valve spring of sorts so that the vtec rocker stays somewhat aligned with the other rockers so that vtec can engage correctly. Or at least that is my understanding/logic of it.
The Type R has higher lift cams and a few more hundered rpms. so stiffer ones were in order. Honda wouldn't do it if it werent needed.
Old Oct 23, 2002 | 12:30 PM
sgT's Avatar
sgT
Default Re: lost motion assembly (tonyxcom)
You are correct sir
Old Oct 23, 2002 | 08:03 PM
CivicEx95's Avatar
Default Re: lost motion assembly (sgT)
thanks for the info. Looks like Acura wants about $30 each for them so that equals $240. Jeez...
Old Oct 23, 2002 | 09:12 PM
tonyxcom's Avatar
you can do much better then that if you look and ask around.
93ricerocket
Jan 19, 2008 07:16 PM
Mr.Sw20
12
Nov 6, 2006 09:03 AM
JDMkidGSR
Sep 8, 2005 05:50 PM
Komsomol
Sep 15, 2003 11:40 AM
reefer_bob
Apr 2, 2002 05:24 PM
