Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
need to change slave cylinder for my clutch hydrolics need help !!!
Old Oct 21, 2012 | 12:26 PM
coltonjamesb's Avatar
Icon6 need to change slave cylinder for my clutch hydrolics need help !!!
hey so my slave cylinders bracket broke allowing it to move around and making my clutch useless , so now i need a new one seeing as i cant get it to stay put i just want to kno what all i need to do to replace it thanks
Old Oct 21, 2012 | 01:23 PM
toyomatt84's Avatar
Sanji
Default Re: need to change slave cylinder for my clutch hydrolics need help !!!
Buy a replacement slave cylinder, install it, and then bleed the clutch line using fresh DOT3 Brake Fluid.
Old Oct 24, 2012 | 06:19 AM
ive bought a new slave cylinder bolted it on connected the lines but still my clutch wont get any stiffer it just falls to the floor when i pump it fluid does come out the bleeder screw but after i tighten it up i pump and pump and it never stiffens up ??? idk wtf to do , maybe im just slow and am doing something wrong ? at least i hope so cause that wont cost me any money ..... think my master cylinder is faulty ??
Old Oct 24, 2012 | 01:21 PM
toyomatt84's Avatar
Sanji
When you bleed your clutch line, what steps do you take? Its best done with 2 people, to avoid any air in the line.
I go with the following procedure:
1. Fill reservoir with DOT3.
2. Place cap on reservoir.
3. Cycle clutch pedal to build up some pressure.
4. Depress clutch pedal, and hold down.
5. Open bleed valve on slave cylinder.
6. Close bleed valve on slave cylinder.
7. Retract clutch pedal.
8. Replace fluid in reservoir.
9. Repeat steps 1-8, until stream of fluid exiting slave cylinder is consistent.
If you're retracting the clutch pedal before closing the slave cylinder, you're not going to be clearing much air out of the line.
Old Oct 24, 2012 | 01:57 PM
yes that is what im doing and i have help its seems to not build any pressure , i have bled brakes before and im told it is the same procedure maybe the slave cylinder i bought is broken idk my one with the broken bracket would force out the arm , but i can compress the arm on the new one have someone pump the clutch and i feel no more pressure on my hand
Old Oct 24, 2012 | 01:58 PM
i dont think i should b having this many problems it seemed like a simple procedure i think im gunna have to call the old man to come down and check it out
Old Oct 24, 2012 | 02:04 PM
toyomatt84's Avatar
Sanji
You don't feel any pressure on the slave cylinder side, after pumping the clutch? Then there's either a ton of air in the lines, or the master cylinder isn't creating any pressure.
Old Oct 25, 2012 | 03:25 AM
yes but the dot 3 coming out is good and steady just not much force behind it , so I guess there's the answer I need a new master cylinder aswell , thanks alot
Old Nov 1, 2012 | 02:58 AM
changed the master cylinder now she works eh ok
Old Nov 1, 2012 | 03:50 PM
toyomatt84's Avatar
Sanji
Glad to hear it.
delsolsi193
11
Apr 7, 2009 09:46 AM
DriveSideWays
Jul 4, 2004 05:07 AM
myhatchrips
Dec 5, 2003 07:21 AM
knightlude
Jun 13, 2003 05:24 PM
safe driver
Nov 14, 2001 03:23 PM
