Car won't start
Old Oct 21, 2012 | 08:51 AM
Reallydatgood20's Avatar
Default Car won't start
I have a 1993 honda accord and it won't start please help I made a video on YouTube check it out http://youtu.be/RzZ9MmPR4Yc
Old Oct 21, 2012 | 09:17 AM
doctorbee's Avatar
Default Re: Car won't start
sounds like it's about to start so it should be getting spark. it would be better to do a spark test to be absolutely certain.
I'd pour some starting fluid into the intake to see if it has a better time starting.
Old Oct 21, 2012 | 09:46 AM
Okay I'm try that what do u think is the cause of the problem ??
Old Oct 21, 2012 | 09:48 AM
It's getting spark I did a spark test yesterday I thought it was the distributor cap so I replaced that
Old Oct 21, 2012 | 10:16 AM
doctorbee's Avatar
if it is indeed an insufficient fuel issue then it may be anything from a weak fuel pump, clogged lines/filter, to faulty injectors
Old Oct 21, 2012 | 10:40 AM
Ok thanks imma see if it is when I get home
Old Oct 21, 2012 | 03:18 PM
Quence's Avatar
could be so many things. did you do anything to the car before or the car just started having this problem out of the blue.
Old Oct 21, 2012 | 06:46 PM
I got it before everything was fine till I changed the battery my last one died so I bought a new one from pepboys
Old Jul 3, 2013 | 12:56 PM
Atlantawino's Avatar
Research replacing the main relay. It tells the fuel pump to pump fuel. Pretty common problem on early 90s Accord. It's in the dash. Had a similar issue with mine.
fire_king
Engine Management and Tuning
Mar 8, 2012 02:45 PM
Happy Gilmore
May 13, 2009 05:21 PM
stunt_driver
Jun 8, 2005 04:55 AM
si00000
Nov 1, 2001 06:10 PM
