Car is acting weird after key is put in ignition...
Old Oct 20, 2012 | 06:29 PM
cryingsuns's Avatar
Default Car is acting weird after key is put in ignition...
Here's the scenario...I get in my 93 Civic Hatch and put my key in..put the clutch down and turn the key. My car go's click click click I turn the key two or three times and then it starts. What situation do I have on my hands? What should I start replacing first?
This just happened last night. I drove my car yesterday and wasn't having this problem. Thanks in advance.
Old Oct 20, 2012 | 06:44 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Car is acting weird after key is put in ignition...
Ignition switch?
Old Oct 20, 2012 | 07:11 PM
cryingsuns's Avatar
Originally Posted by grumblemarc
Ignition switch?
Yeah that wouldn't be too bad. My mechanic just put in my LSD yesterday(I forgot to mention that). He's good, really good, so I want to believe that he didn't or forgot to tighten something up. Could that be possible? Can I get the ignition switch at Napa or O'Reillys? Is it hard to install?
Old Oct 20, 2012 | 07:14 PM
99civ's Avatar
When I got my hatch, the starter was bad so I went ahead and got one from Auto Zone and replaced it. Since then, if the car sits for a period of time... anywhere from maybe 8 hours to max hours, it always takes a couple key clicks to starts. I have had ground issues on my battery also, so it could be either/or. I'm not too worried about it and have never asked myself why because essentially, it does turn over which is all that matters to me..
Old Oct 21, 2012 | 07:17 AM
AddiXz's Avatar
Check if you have any ground problems. I had this last weekend bought a starter engine from the scrapyard and found out it was just ground -_-'.
This bracket:
Originally Posted by My {slow} 92 Carb to FI Conversion and rebuild project.
The bracket with the yellow plastic clamp and the ground cable attached to it
Was not attached properly for some reason and was the problem with me.
Is it the same sound as i made a little clip of in my {slow} 92 Carb to FI Conversion and rebuild project topic?
jdm_ek_noob
Jun 26, 2013 02:14 PM
Defiant_dc
Aug 14, 2009 04:29 AM
1badteg
Dec 18, 2008 03:36 PM
Honda Bull
Feb 23, 2006 05:16 PM
Briman2021
Feb 3, 2004 12:03 PM
