2008 Civic door locks jammed
The door locks jammed in the locked position and would not release with the remote control, the interior locking switch or the door key. It started with the driver's door and then every other door as the plastic catch was moved. I thought the door would have to be dismantled to get at the lock, but it is easily fixed. Just pull up on and hold open the driver's door handle while unlocking on the switch - gently pull the plastic locking catch in the door back into the open position and the problem is solved. It does not need to be forced or dismantled.
Intercooler
Nov 18, 2004 08:43 PM
