'90 accord cuts out while driving..wtf!?
Old Oct 19, 2012 | 04:03 PM
hatchinprogress's Avatar
Default '90 accord cuts out while driving..wtf!?
its a 1990 accord ex (auto) w/about 208,000 miles on it stoc everything (except aftermarket alarm)
no c.e.l. and no codes stored on ecu
but when driving (freeway speeds) the car cuts out (for like a second) and then kix bac on....right now is sporadic but feels like its getting worse! (just started a few days ago)
where do i start???
Old Oct 19, 2012 | 05:58 PM
doctorbee's Avatar
Default Re: '90 accord cuts out while driving..wtf!?
sounds like ignition switch. with the car running try jiggling the keys to see if it cuts out.
Old Oct 20, 2012 | 03:44 PM
Thanks for the help.....jus tried it(me in pass. Seat my girl drivin) not excessive(imo) play in the ignition....an didn't cause it to cut out.
I don't know what's causin this...drivin me crazy!
Old Oct 22, 2012 | 04:38 PM
Bump 4 help
Old Oct 22, 2012 | 05:12 PM
Yerba's Avatar
we're in the same boat. easiest fix is probably the relay under the dash. worn out solder over time and miles. some guys drop new solder on the old part, others take a chance on ebay. I replaced the distributor because it has a chip in the middle of it that goes bad - didn't help. I have a new fuel pump - but you've got to drop the tank in 1990 so that will take me being in a better mood, the fuel filter was easy - but be careful with the charcoal canister nipple - it can snap easily if the rubber vacuum hose sticks. Buy a can of SeaFoam and dump it in the gas. It may clean out some crud, doesn't hurt.
Old Oct 22, 2012 | 06:49 PM
doctorbee's Avatar
try resoldering the main relay
http://www.google.com/url?sa=t&rct=j...NXvXJgKV9yyJ9A
Old Oct 23, 2012 | 03:16 AM
bawb's Avatar
What accessories and lights are on when your car cuts out. I doubt it's a fuel pump, don't throw parts at it, diagnose the problem.
Follow this guide http://techauto.awardspace.com/ignition.html
Old Oct 23, 2012 | 12:24 PM
StreetsideStig's Avatar
I'm with Dr.Bee. Don't be so sure it's spark. The Main Relay is notorious on these.
Old Oct 24, 2012 | 01:37 AM
brakedrum's Avatar
I would say Ignition Module (Ignitor) but usually a bad Ignitor cuts you off with no kicking back on. Has your Accord ever had the O2 Sensor replaced? Is there any ongoing stumble or bogdown accompanying the engine cutting off? A really old O2 can fail with no code and cause a condition similar to a miss but is really more a choking because of the bad air/fuel mix the bad info from the bad oxygen sensor sends to the ECU > IACV and eventually the combustion chambers. It becomes a drivability issue if it's bad enough.
jimwalkins
Sep 18, 2015 06:22 PM
Rat Rod
Oct 13, 2010 05:12 PM
boost and bass
Jul 17, 2010 06:26 PM
euroborn1
Apr 22, 2010 05:50 PM
cwhonda1
Jun 6, 2006 08:48 PM
