92 eg won't start
Old Oct 19, 2012 | 02:25 PM
Int3graz's Avatar
Default 92 eg won't start
92 civic vx hatchback without ps
Went to start it today after sitting a few weeks and the battery was dead. So jumped it started briefly and died. Tried again and the belts started screeching extremely loud and a ploom of smoke shot up from the driver side near the ac pump before stalling.
Possible my AC pump or alternator pulley froze up after sitting such a short time?
Belts are tight and in tact. I couldn't visually verify what was going on since I was starting the car.
What do you thinks going on? Charging the battery for the night before doing any more diagnosis.
Old Oct 19, 2012 | 04:51 PM
jermo's Avatar
Default Re: 92 eg won't start
Was it running just fine before you let it sit for a few weeks?!? im just wondering why u let it sit for a few weeks...
i definitely do not think the ac pump or alt pulleys froze up so i wouldnt start there...
i cant really think of what the ploom of smoke could be from, maybe from a leak in the header somewhere...if it started briefly it def seems like you are getting crank and spark, is there gas in it? lol
Old Oct 19, 2012 | 04:52 PM
Aaron50525's Avatar
got an oil leak and i cant post a thread cause i just signed up. the leak is right under the cam gears http://s11.postimage.org/urbsjxqwj/Untitled.png Please help asap
Old Oct 19, 2012 | 05:14 PM
mayfly's Avatar
dont jack someone else thread.
Old Oct 19, 2012 | 05:16 PM
mayfly's Avatar
OP were you having issues with the AC pump before?
it sat for a few weeks? could be bad fuel but most likely not because it wasnt long enough for fuel to go bad.
have you checked your spark?
when trying to turn it over do you smell fuel from the exhaust?
Old Oct 19, 2012 | 08:23 PM
Int3graz's Avatar
Yah was running great, just haven't needed to take it out. Yep got gas I think something froze up somewhere
Old Oct 19, 2012 | 08:24 PM
Int3graz's Avatar
Nope I was not. Fuel should be fine nope ill check more tomorrow. Thanks guys
Old Oct 20, 2012 | 07:19 AM
Int3graz's Avatar
It's definitely my alternator pulley not spinning... How does that happen my car sat for a few weeks after running fine and now it's frozen up. Trying some pb blaster on it but is it likely my alternator is shot?
Old Oct 20, 2012 | 08:17 AM
Former User's Avatar
Replace it.
Old Oct 20, 2012 | 12:21 PM
Int3graz's Avatar
Originally Posted by RonJ@HT
Replace it.
Yep I'm going to any recommendations for brand or type sounds like these remanufactured ones aren't very good.....
Old Oct 20, 2012 | 12:23 PM
I have remanufactured alternators in my Civics. They come with lifetime warranties so replacements come at no cost.
Old Oct 21, 2012 | 09:29 AM
Int3graz's Avatar
Okay thanks that's what I went with. Now I just gotta get this damn ac tensioner pulley bolt loose. I might as well of just tried rebuilding the alternaor while I was at it ! Oh we'll better than watching tv!
miked123
Jun 16, 2013 04:59 PM
TurTLe*
Oct 20, 2011 02:51 PM
osn grind
12
Aug 15, 2011 08:47 AM
ehLAaay
15
Jan 25, 2011 10:55 PM
Bloopsta
Dec 5, 2006 10:26 PM
