Converting from AWD to fwd
Is there a quick way to do this or should I just pick up a ls gearbox and swap it in (mine is a 99 5 speed crv)? There is nothing wrong with my drivetrain now, its just I will never utilize it and the extra rotating mass is keeping some performance from me along with mpg's (while it may not be a noteworthy number it is still there). Thanks guys
yeah. the awd doesnt really ever engage if you are driving normally though, so removing it for summer or whatever is really about 99.9% pointless. the only way i would do it is if your diff is effed from lack of change and making that grinding noise. if flushing hadnt fixed it.
BUT if i ever swap i will likely convert to fwd though, to save weight and avoid blowing anything up.
I did my timing belt yesterday and noticed my rear driveshaft's u joints were horrible. Guess thats what 221k miles will do for you...I pulled the driveshaft out and it drives fine. Going to order some new ujoints and throw them in hopefully before the snow gets here.
I am not positive but I dont think you can pull the rear axles out because the bearings are different than the FWD ones...I might be wrong about this but it was something I read in passing. Just take a look at the bearing setup if you are going to completely remove the diff and rear axles.
