Cv axle removed, hard shifting. HELP!
Old Oct 19, 2012 | 05:50 AM
AcuraTeg32's Avatar
Default Cv axle removed, hard shifting. HELP!
Ive got a 92 integra ls 5 sp
just had a guy off craigslist help install coilovers
and he didnt know what he was doing and ended up taking the axle out
after banging the crap out of it for 2 hours finally got it back in (so he says)
and now the shifter is extreamly hard to shift in 1st and 2nd.
3rd and 4th are not as bad and 5 is easy as it always was.
fluid is full and car shift easy with car off.
please help get my butter shifting back!
car doesnt make noises when turning or anything.
Old Oct 19, 2012 | 07:14 AM
DeCePtEgRa's Avatar
Default Re: Cv axle removed, hard shifting. HELP!
A guy off craigslist? Was he certified to work on cars? If so call the BAR on him if not your screwed. It doesnt take beating new axles in just some grease on splines.
Old Oct 19, 2012 | 08:09 AM
JuicedUpRice's Avatar
for real man you need to make him fix that or something..
he probably forcefully hammered the axles in without even feeling if it was lined up correctly and now its probably jammed in there.youre risking it stripping in there..
Old Oct 19, 2012 | 08:20 AM
cvcrcr99's Avatar
So this "guy off of CL" is a metaphor for a legit shop, right?
Pull the axles and look for damage. Not much we can do for you at this point I would imagine.
Lesson learned I assume. Do it yourself, or take it to a reputable shop.
Old Oct 19, 2012 | 09:20 AM
JmurGSR98's Avatar
Why did he take the axles out? Removing the axles has nothing to do with installing coilovers. Youre gonna hsve to remove your axles and inspect.
Old Oct 19, 2012 | 09:29 PM
83rolla's Avatar
most likely he forced the axles in bro its such an easy job to do just look on google for videos n write ups i just did my axle yesterday cuz **** was leaking tranny oil...or maybe just maybe the actually thing thats inside the boot of the axle came out of place n by doing all that banging with a hammer he might of fucked it all up it can happen but gl tho
Old Oct 19, 2012 | 10:42 PM
kchungb17a's Avatar
Somebody does not know how the BAR works.
Yes, axles do not need to be removed to install "coil overs".
Your trusty CL mechanic may have banged on your shift linkage. Hard to imagine what else would cause you hard shifts after R&R'ing your axles. You should take this to an actual mechanic for inspection.
Old Oct 19, 2012 | 11:03 PM
DeCePtEgRa's Avatar
I dont think shift linkage is any where near driveaxles or coilovers? At least not on my 91 teg.....op if the guy was a mobile mechanic the bar will help you
Old Oct 19, 2012 | 11:23 PM
kchungb17a's Avatar
For the BAR to be able to help, the shop or professional must be a member of the BAR. I'm guessing the CL guy does not qualify.
On any B-series tranny, the shift linkage is close enough to where the axles go that an errant hammer swing, particularly from a CL professional, could bend them.
Axles typically slip right into the the differential with little effort. Who knows what this guy did with his trusty hammer.
Old Oct 19, 2012 | 11:39 PM
DeCePtEgRa's Avatar
No **** he has to have his ard license then they will. My buddy just started his mobile mech business last month and has a CL add. I know it wasnt him though since hes done a bunch if axle jobs.
No one likes a know it all *******, we all didnt get to have b16s.....that sounds like a real poor designed setup.
Um he hit it dipshit, I dont see how you make it a day in this world without the same thing happening to your **** talking mouth.
Old Oct 20, 2012 | 08:50 AM
kchungb17a's Avatar
What is it with you guys? Can't make a simple post without getting all worked up. I'll try to make this as simple as possible so that you can understand it.
Any monkey can buy a hammer and a screw driver and call himself a mechanic. He doesn't need any certification or training, just somebody who is willing to let him beat on their car. The BAR cannot do anything about this guy. This would be a case for the civil courts.
I'm sorry that you feel inadequate about not having a B16. Not sure why you brought that up. I'm here because I'm trying to help some of these guys that have questions about their Integras. Sometimes I have questions too and others answer them for me. I thank them, not call them know it alls and *** holes.
I've read many of your posts and you seem really easy to anger. If you have some sort of inferiority complex or something, check it at the keyboard. If you can't have an intelligent exchange with other people on this board who are trying to help others, then maybe you should find another forum.
Old Oct 20, 2012 | 10:55 AM
fcm's Avatar
fcm
Old Fart
X2
This guy gets his panties in a knot all the time, he needs anger management, his go to response to anyone he disagrees with is to berate them and call them names, not unlike the grade school bully he probably was.
The best way to deal with his kind is to just ignore him.
Not sure why a mod has not reprimanded him already, if he opens his pie hole again with is dribble, I will just have to point it out to a mod.
Where you at Jimmy? 94
Old Oct 22, 2012 | 02:27 PM
AcuraTeg32's Avatar
I appriciate the few of you who gave me some words of advice, didnt mean to upset anyone.
the car is my dd and im a pretty broke younger guy.
the car is hard to get into gear but once i do it seems to take off fine.
am i damaging the transmission or at worse damaging the axle?
axles are $50 at autozone and i can replace soon if its recommended.
As far as craigslist goes ive learned my lesson.
cheaper work gets you more expensive bills to repair the cheap work.
i do most stuff myself but a 20 year old suspension needs torches and some specialtly tools, so i had to get a hand.
thanks again guys, looking forward to learning new stuff in this forum.
Old Oct 26, 2012 | 05:10 PM
DeeC2's Avatar
10 Year Member
why are you guys attacking this guy? why would you ever let someone work on your car off craigs anyway... you sound like you dont even know what your talking about, and it sounds like this CL guy is really the op. just sayin
Old Oct 27, 2012 | 09:15 AM
DeCePtEgRa's Avatar
There is a lot of hypocritical members who can dish it out but not take it on HT I'm not mad nor have anger issues but that's members of HT trying to diag a human being
Randysi
13
Jun 29, 2011 07:58 PM
tjin83
Aug 25, 2006 06:54 PM
John.
Jul 28, 2006 10:56 AM
Death_to_Thieves
Aug 24, 2004 09:39 PM
92civeg
Aug 24, 2004 08:55 PM
