H22 Prelude not starting
Old Oct 18, 2012 | 02:32 PM
SrVShayner's Avatar
Default H22 Prelude not starting
So ive been reading and reading and reading and trying and trying and trying ...
when i turn the key fuel pump kicks in, turn it again and ONE CLICK then nothing.
i checked my grounds, they were fine, i was missing a tranny ground but added one and still nothing, tried another battery, but nothing.
any other ideas? i dont wanna spend on a new starter if thats not my problem.
any help would be helpful thanks!
Old Oct 18, 2012 | 04:02 PM
snobordboy's Avatar
Moderator
Default Re: H22 Prelude not starting
Try giving the starter a smack with a hammer and trying again.
Usually a weak battery the solenoid will click fast a few times then slow down.
Maybe putting the car in neutral, and jumping from the battery to starter to verify it operates, or taking it to a parts store and get them to bench test it.
Old Oct 18, 2012 | 05:38 PM
SrVShayner's Avatar
what do you mean by jumping the battery to starter?
Old Oct 18, 2012 | 05:55 PM
yroachy's Avatar
Pull off the small black and white wire and use a jumper wire from the pin on the starter to b+ terminal. If it doesn't turn over your starter is pooched. MAKE SURE YOU ARE IN NEUTRAL!
Old Oct 18, 2012 | 06:34 PM
SrVShayner's Avatar
k i did that with the starter in and out, it didnt start the car just ticked and when i took it out and did it, the rod comes out but the actual teeth dont spin. so im assuming the starter is as u would put it POOCHED?
Old Oct 18, 2012 | 07:19 PM
yroachy's Avatar
Yep
Old Oct 19, 2012 | 02:36 AM
holmesnmanny's Avatar
If it's original denso it's probably just the contacts that are bad. You can confirm this by hammering the starter with something solid before trying to start it when it's acting up(like snobordboy said).
Old Dec 2, 2012 | 11:35 PM
f20bprelude's Avatar
Replace the starter. had the same issue on my 93vtec prelude
Old Dec 4, 2012 | 07:49 PM
P. Hunter's Avatar
just try tapping on the starter as someone trying to start the car... usually that will get it to start up.. starters are not that expensive so its not a huge deal to buy one
Old Dec 8, 2012 | 05:25 AM
DoMiNiKiNG947's Avatar
Replace the starter. If by any means it still doesn't start, return it and refund. By your description, it definitely sounds like the problem is the starter.
Old Dec 8, 2012 | 03:07 PM
Richarddsayss's Avatar
Can anyone answer this.
H22a1 obd2 that came factory in a 1996 lude. The engine itself has 95 stamped on it. I did read that when they made an engine in 95 it didn't get into a car until 96. I bought the engine I am describing and trying to make sure it's obd2, it does have smaller dizzy plug and 4 wire o2 also the third mounting hole for the dizzy is a perfect circle but I'm wondering if my engine says 95 could it still be obd2
Old Dec 8, 2012 | 11:46 PM
I'll say check the oil pump and check if crank sensor plug is there connected and not sure if obd2 had internal coil in that year but that I know of, internal coil is obd1 and obd2 is external coil. Coil as ignition coil from distributor.
Old Dec 8, 2012 | 11:54 PM
Yes, usually the engine stamp is the year before because it takes a while to get from engine creation to end user.
Old Dec 9, 2012 | 11:40 PM
Hondaguy83's Avatar
It's not the starter. It's a seized engine.
hondachris1994
Aug 15, 2019 03:07 PM
hondachris1994
12
Nov 9, 2017 05:15 PM
caliskier
Nov 28, 2012 05:18 PM
go2sleep
May 6, 2007 08:42 PM
EF9 JAMS!!!
Sep 23, 2004 10:21 AM
