1999 Civic LX Auto Tranny Hard Shift?
What would cause my transmission to hard shift? Doesnt happen every time but when it does it is usually with 1st and 2nd gear?
It has 160k miles on it and original fluid i believe.... Im afraid to change it due to everyone i talked with said if it hasnt been regularly changed that changing it for fresh stuff might do more harm than good..
Any suggestions? BTW the fluid level is good.
One last think one of my motor mounts needs replaced since there is pretty much nothing left of it... could this cause it?
search...160k trans fluid change....i started the thread.
I changed mine at 160k, over a year ago, no problems. shifts fine.
go to honda, get 9 quarts, and start doing cycles of 3.
bad motor mounts cause excessive engine vibrations which i have heard of other people can be confused with rough shifts normally with m/t i havnt heard about them causing problems with a/t tho it still is a possibility
Nate.Hamm
Jan 12, 2021 01:45 PM
specialty
Honda CR-V & Element
Oct 16, 2012 05:37 AM
thecorey
12
May 18, 2005 04:23 PM
