alright, this is a unigue wideband O2 question......
Old Oct 17, 2002 | 05:54 PM
Boostless97Lude
Guest
Posts: n/a
Default alright, this is a unigue wideband O2 question......
is it possible to hookup a wideband O2 sensor to an autometer air/fuel guage, and it be accurate?
if not, then is there someone that makes a wideband O2 that has a display that i can mount somewhere in the cockpit so that it can be read, and doesn't look out of place?
Old Oct 17, 2002 | 05:57 PM
dustin's Avatar
Default Re: alright, this is a unigue wideband O2 question...... (Boosted97Lude)
1) no
2) fjo, or the diy wideband with the impossible-to-get sensors
Old Oct 17, 2002 | 05:59 PM
TurboedGSR's Avatar
first you need something that will read the sensor signal (like the techedge unit). Then you can hook up a lcd read out and hook it up to the output of that unit
BTW ebay sells the lcd read out and they can mount it on a 2 1/16" pod for you, but really it's only a 0-5voltmeter
Old Oct 17, 2002 | 06:03 PM
TurboedGSR's Avatar
Default Re: alright, this is a unigue wideband O2 question...... (dustin)
1) no
I have two new ones for sale in the classifieds
Old Oct 17, 2002 | 06:06 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: alright, this is a unigue wideband O2 question...... (TurboedGSR)
what about my seconday O2 in my Prelude, when i get my Hondata, i will eliminate the 2nd O2, so can i just wire a guage into it
Old Oct 17, 2002 | 06:09 PM
dustin's Avatar
The secondary O2 sensor is just another on/off stock sensor.
Old Oct 17, 2002 | 06:10 PM
dustin's Avatar
the techedge diy wideband output is not linear. You need the display they offer along with the unit.
Old Oct 17, 2002 | 06:15 PM
TurboedGSR's Avatar
sorry i was just going by their (the seller on ebay) description
sorry if i confused anyone
Old Oct 17, 2002 | 07:02 PM
Boostless97Lude
Guest
Posts: n/a
oooooooookkkkkaaaay. then where can i get a wideband O2 and a readout that i can mount in a 2 1/16 pod?
Old Oct 18, 2002 | 07:25 AM
Boostless97Lude
Guest
Posts: n/a
ttt
Old Oct 18, 2002 | 07:40 AM
falcongsr's Avatar
What is this crap?
you'll have to fabricate this part as far as i know. i guess if you get the techedge display you could rig it up so that the LEDs are separate from the circuit boards.
Old Oct 18, 2002 | 07:46 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: alright, this is a unigue wideband O2 question...... (falconGSR)
ok, so, what if i buy an autometer guage and wire it to the O2 sensor just to make sure it doesn't lean out when i am driving, but when i tune it, i just use a wideband, then remove it when i'm done? i am having a shop tune it, so they have one..... would this be OK?
yes, i know, i sound like a complet n00b, i'm just wanting to be sure everything is right the first time.
Old Oct 18, 2002 | 07:54 AM
falcongsr's Avatar
What is this crap?
not sure...but you gave me an idea...you *could* take the output of the techedge unit ( 1v - 4v) and by using a simple opamp circuit scale it so that you could feed it into an autometer gauge (0v - 1v). but, since its nonlinear like dustin said, you could calibrate it to be accurate at 1 particular point and then you'd either see if you're rich or lean if it was left / right of that point...but thats a lotta work just for some pretty lights...hmmm...
edit - plus you'd have to invert the voltage since 4v is lean on the wideband and 0v is lean on the narrowband. too much work - for me anyway
King V
Nov 30, 2007 04:40 AM
JDMlyfestyle
Mar 30, 2004 09:48 AM
red_sir
Jul 23, 2003 02:14 AM
speed
Nov 19, 2002 04:28 PM
Qwikrex
Jul 29, 2002 03:50 PM
