B18 not starting NEED HELP
Old Oct 17, 2012 | 09:16 AM
boostedhatch69's Avatar
Default B18 not starting NEED HELP
found our problem. crank lock
Old Oct 17, 2012 | 09:17 AM
Default Re: B18 not starting NEED HELP
forgot most important info
B18a1 block with a 96 or 98 B20 head
Old Oct 17, 2012 | 10:42 AM
JuicedUpRice's Avatar
what headgasket did you use?(as in for what motor)
check the ecu ground on the thermostat.
codes?
Old Oct 17, 2012 | 05:59 PM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
Also check and make sure there is power at the injectors, when ign. switch is in BOTH the run and start positions. 94
ownzorzed1
Oct 25, 2011 03:16 PM
jdmegcivtunner
Sep 12, 2010 03:39 PM
Fresh Ej2
Mar 17, 2009 09:49 PM
kurs
Jan 25, 2009 12:27 PM
Frank_2.0L
Sep 20, 2005 07:21 AM
