Civic Wont Start Help.
Old Oct 17, 2012 | 08:57 AM
chrisff521's Avatar
Default Civic Wont Start Help.
93 civic will not start just replaced the ignition and have put multiple starters in and a new
relay new dizzy and no start will not even crank over . ? is it my injectors i just did the swap a single v the clutch has no pressure yet i didnt bleed it yet could that be the problem please help.
Old Oct 17, 2012 | 09:19 AM
chrisff521's Avatar
Default Re: Civic Wont Start Help.
bumpppppppppppppppp anyone ?
Old Oct 17, 2012 | 10:06 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Model, Engine, ECU, CELs??????
Old Oct 17, 2012 | 10:27 AM
LadyCamouflage's Avatar
Spark plugs? Wild guess.
Old Oct 17, 2012 | 12:18 PM
chrisff521's Avatar
d16z6 all stock ecu idk if there are cels i just dropped it in it wont start
when i go to tap the starter it makes a whining noise by the alternator
and i changed the spark plugs also nothing differnt
Old Oct 17, 2012 | 01:58 PM
97civkid's Avatar
Is it gettin fuel? Check all ur grounds and fuses
Old Oct 17, 2012 | 03:20 PM
vitamin_c95's Avatar
are the belts turning when you crank?
Old Oct 17, 2012 | 04:20 PM
97civkid's Avatar
It doesn't crank he said
Old Oct 17, 2012 | 06:30 PM
chrisff521's Avatar
all fuses and grounds are on it does not crank
Old Oct 17, 2012 | 07:24 PM
D16SiHatch's Avatar
automatic starter on manual trans?
If its not even cranking over you cant begin to figure out if there is a timing, ignition, spark, etc issue.
Old Oct 17, 2012 | 07:28 PM
alphalanos's Avatar
if it wont crank it has to be like battery, connections, clutch pedal switch, etc.
when you put the key to on position do you get dash lights?
Old Oct 18, 2012 | 06:12 AM
97civkid's Avatar
When u try'd other starters did they also whine
Old Oct 18, 2012 | 09:35 AM
chrisff521's Avatar
yea also a whining noise could it be the clutch pedal switch
because it has not been bleeded yet .
Old Oct 18, 2012 | 11:05 AM
97civkid's Avatar
Check the ground on ur thermostat
Old Oct 18, 2012 | 11:18 AM
chrisff521's Avatar
i forgot to mention that it was converted to auto to stick by previous owner so maybe the clutch is a problem ?
Old Oct 18, 2012 | 11:22 AM
chrisff521's Avatar
the thermostat ground is connected
Old Oct 18, 2012 | 11:34 AM
chrisff521's Avatar
severl pictures of the engine .
Old Oct 18, 2012 | 12:07 PM
97civkid's Avatar
Find the wires from where the auto shifter was an takes picture of them
Old Oct 18, 2012 | 01:10 PM
so...did you just do the swap? Has it ever ran in this configuration?
Old Oct 18, 2012 | 04:00 PM
Sr420Det's Avatar
what he said, gotta have the park neutral safety switch right.
Old Oct 18, 2012 | 04:52 PM
97civkid's Avatar
Old Oct 18, 2012 | 05:18 PM
slomofo's Avatar
GDD Member
First thing's first....
Grab a socket and a ratchet, then try turning the engine by hand. Does the timing belt move? If yes, move to the next step.
Take the small wire off the starter, go to the inside of the car and put the key in the ON position with the car in neutral.
Take a jumper wire and go from the small terminal of the starter to the terminal with the power wire on it. The car should start cranking.
Let me know if it cranks/starts from that point.
Old Oct 18, 2012 | 05:23 PM
Bystrov's Avatar
i had this same issue on my DA..... turned out to be the malfunctioning alarm system. ripped it out, cleaned up the wires where it was spliced in to, and cranked right up.
Old Oct 19, 2012 | 05:33 AM
chrisff521's Avatar
i didnt try what you told me but i tried multiple other starters and nothing do you think it could be the dizzy?
Old Oct 19, 2012 | 09:16 AM
slomofo's Avatar
GDD Member
Why would the distributor cause a no crank situation? Honestly dude, you're making things harder than they are.
