p0171, p0170, p1297
Old Oct 17, 2012 | 08:45 AM
Veggie Man's Avatar
Default p0171, p0170, p1297
I have all these codes now. It happened 50 miles after I refilled my car with unleaded regular after seeing for two tanks how my car reacted to non ethanol premium. so no code with the premium, codes 50 miles after the unleaded regular. Any relation?
And should I just change out the ELD? I hear I have to get the entire fuse box. Is that right? Or how do I replace it? Its kinda hard to find info on this since the issue is mostly on civics.
Old Oct 17, 2012 | 02:25 PM
jdowen2's Avatar
Default Re: p0171, p0170, p1297
o2 sensor?
Old Oct 17, 2012 | 03:24 PM
jdowen2's Avatar
Also possible fuel filter or fuel pump. Test the fuel pressure.
Old Oct 17, 2012 | 07:00 PM
Veggie Man's Avatar
o2 sensors are a year old but could be faulty. fuel pump perhaps but thats apparently not common in hondas. Im focusing more on the ELD dictating all this as a possibility. Its hard to find info on it with accords.
Old Oct 18, 2012 | 11:50 AM
jdowen2's Avatar
Per the FSM, reset codes, start car and turn on headlights. Does code p1297 appear? If so, replace ELD. http://www.elementownersclub.com/for...ad.php?t=51803
Old Oct 18, 2012 | 12:51 PM
Veggie Man's Avatar
Apparently the ELD on my car cannot be replaced by itself and I need to buy a new fuse box if its the issue. But the code does not come back on after I do this.
Old Oct 18, 2012 | 09:06 PM
jdowen2's Avatar
If the code reappears you probably have a flaky ELD. See
. Although it's for a Civic I'd bet the Accord ELD is serviceable.
Old Oct 19, 2012 | 08:17 PM
Veggie Man's Avatar
It is not actually. The 5th gen accords have the ELD built into the fuse box. But it seems based on the code troubleshooting that the issue may be a connection more than the ELD because the CEL comes on randomly. Im going to check the g101 ground and see if its being grounded correctly. The other two codes may be o2 sensor issues though. I'm not sure yet.
Old Feb 13, 2013 | 07:00 AM
Veggie Man's Avatar
Update on this post. This was a while ago...
But the 1297 went away after wiggling the ELD wires and the other two went away with a new OEM o2 sensor. Dont buy aftermarket sensors.
DEFIANCE
Aug 14, 2014 09:38 PM
TomCurllyFry
Dec 2, 2012 08:50 PM
BigDaddyRich
Apr 11, 2005 03:25 AM
triple_s1x
Dec 10, 2004 07:47 PM
importimage
Jun 30, 2003 04:27 PM
