AP1 S2000 cluster in an 88 CRX
Hello guys
I am in need of some serious help, I am having a huge PITA with this cluster and getting the speedo to work. I am using the Healtech Speedohealer, I've wired everything in as far as running the signal wire to the speedohealer from the vss and wiring in the vss with a power and ground. I know for sure I am getting a signal to the speedohealer because I did the speedohealer test for signal input but it is not outputting to the cluster. If anyone can shed some light on this situation I would really appreciate it.
you need to set the numbers on the Speedohealer to 3700. I know you have to enter a number on it and 3700 is the correct one. I have one fully functional in my Rex
you'll have to check the website on the instructions. Its pretty simple but it was so long ago, I dont remember
http://www.healtech-electronics.com/
Hey man thanks a lot thanks to you I got this working finally, honestly I've been talking straight to healtech in Australia and they didn't even tell me to do that. After you told me to input the numbers it worked. Thanks
xalents23
184
Feb 22, 2024 09:48 AM
