Buying an '09 LX-SR--have only seen love for the Si here!
Why no love for the LX-S? I am picking up an 09 LX-SR sedan for 13,000 with 34,000KM on it; figured I couldn't go wrong for the price, it's mint.
Anybody have any thoughts on the car itself? I have done my research but haven't seen anything about this model in particular. Any problems with this year/model? Anything good about it?!
Cheers
Cheers
Why no love? No k20, no 6 speed, no LSD! Also they never recalled civic si engine blocks
Problems, all 06-11 civic have sunvisor issues, by 09 I think the engine block is no longer a concern, shocks/struts seem to go bad from anywhere between 30-60k, seems likes non si's are kinda prone to steering rack issues/leaking(not a lot, but I've never sold a rack for a si lol) floor mats seem to be made of shitty material and wear out somewhat quickly(get all seasons) paint of certain colors have clear coat issues(think its mainly black and Fiji blue) uhhh....that's all I can think of ATM.
A05-032.pdf ALL- Navigation system information and inspection- informational
A05-041.pdf ’06-all - Civic audio Unit Diagnosis -informational
A05-042.pdf – ‘06 Civic Sedan, Coupe: PDI and New Model Information
A05-044.pdf – ’06-’08 Civic with Navi and Hybrid with Navi- PDI of the DVD Navigation System With Voice Recognition
A05-047.pdf ’06 all- Paint Codes
A05-055.pdf - 2006 Civic Hybrid: PDI and New Model Information
A05-061.pdf - Safety Recall: 2006 Civic Accelerator Pedal Inspection
A05-066.pdf – ’01-’06 ALL- Universal Front Subframe Removal Adapter
A06-001.pdf – ALL - Audio, Navigation, and RES Unit In-Warranty Exchange, and Audio and DVD Player Out-of-Warranty Repair
A06-002.pdf - ’06 2-door Safety Recall: ODS Unit Does Not Suppress Airbag Deployment, and DTC 82-12 or 83-22 Is Stored
A06-006.pdf – ’06 2-door EX- Rear Shelf Rattles When Playing the Audio System
A06-007.pdf – ’06 2 and 4 door. SRS Indicator Stays On, and DTC 86-16 Is Stored
A06-008.pdf- ’06 - Immobilizer-Keyless Control Unit or ECM/PCM Cannot Be Rewritten
A06-011.pdf- ’06-’08 Civic all - Immobilizer System (Type 6)
A06-013.pdf- ’06 Hybrid- Product Update: Gauge Control Module Displays Erratic Average Fuel
Mileage
A06-014.pdf- ’06-07 4-door and hybrid - Front Door Glass Comes Out of the Channel
A06-020.pdf- ’06 4 and 2 door - Engine Oil Leaks and Power Steering Fluid Leak
A06-028.pdf- ’06 GX 2006 Civic GX: PDI and New Model Information
A06-031.pdf – ’06 See Affected - Front Seat Clicks When Sliding or Does Not Slide
A06-034.pdf – ‘06 See Affected- Keyless Remote Intermittently Does Not Unlock the Passengers’ Doors
A06-036.pdf – ’06 See Affected- Immobilizer Indicator Is Blinking, Engine Won’t Start
A06-048.pdf – ’06 ALL- MIL Comes On With DTC P0116
A06-052.pdf – ’06 SI- Engine RPM Does Not Immediately Drop When Shifting Gears, Vehicle
Surges When Driving in 1st Gear
A06-059.pdf – ’06 See Affected- Buzzing From the Engine at Low RPM
A06-060.pdf – ’06 See Affected- Rattle From Right-Front of Vehicle When Driving Over Bumps
A06-068.pdf – ALL - Vehicle Pulling or Drifting
A06-069.pdf – ’06 2-door- Safety Recall: Rear Window or Quarter Glass Rattle or Looseness
A06-070.pdf – ’06 2 door and SI- Product Update: SRS Indicator Stays On, and DTC 86-25 Is Stored
A06-071.pdf – ’07 Sedan and coupe- PDI info
A06-072.pdf – ’08 ALL- TPMS Sensor Tool Usage
A06-075.pdf – ’07 hybrid all- PDI info
A06-076.pdf – ’07 GA ALL- PDI info
A06-080.pdf – ’06 4-door See Affected- Roof Molding Is Stained
A06-082.pdf – ALL- Tubeless Tire Repair Information
A06-086.pdf – ’06 and ’07 See Affected- MIL Comes On With DTC P0455
A06-089.pdf – ’07 ALL- Pint codes
A07-004.pdf – ’06 & ’07 See Affected- Front Seat Cushion Cover Is Loose
A07-008.pdf – ALL- Clarification of Honda Unibody Repair Policy
A07-009.pdf – ’06 hybrid all- Safety Recall: DC-DC Converter Output Cable Is Pinched by IPU Lid
A07-012.pdf – ALL- Music Link (For iPod) General Information and Symptom Troubleshooting
A07-030.pdf – ALL with A/C- A/C Leak Detection
A07-041.pdf – ’06 hybrid ALL- Occasional High Engine RPM During Deceleration
A07-043.pdf – ’06 4-door- Popping Noise While Turning
A07-044.pdf – ’08 ALL- Paint Codes
A07-048.pdf – ’08 sedan and coupe- PDI info
A07-066.pdf – ’06 & ’07 See Affected- Safety Recall: Rear ABS Wheel Speed Sensor and O-Ring Inspection
A07-058.pdf - 2008 Civic GX: PDI and New Model Information
A07-061.pdf – ’06 & ’07 See Affected - Safety Recall: Brake Pedal Position Switch May Fail
A07-062.pdf – ’06 & ’07 See Affected- Poor A/C Performance During Acceleration
A07-071.pdf – ’06 & ’07 See Affected- Windshield Wipers Intermittently Do Not Park or Turn Off
A07-077.pdf – ’06 & ’07 All with AT- Brake Pedal Feels Hard in the Mornings or in Cold Weather
A07-078.pdf – ’06 & ’07 coupe and SI 2 and 4 door- Pop or Clunk From the Front Suspension While Driving Over a Bump After Turning
A07-081.pdf – ’98 thru ’07 GX- Safety Recall: Fuel Tank Thermal Insulator
A07-085.pdf – ALL - ATF Leak Detection
A08-001.pdf – ALL except SI- Uneven or Rapid Rear Tire Wear
A08-003.pdf – ALL- Update the PCM When Replacing the Transmission
A08-009.pdf – ’08 hybrid PDI info
A08-013.pdf – ’07 & ’08 See Affected- MIL Comes On With DTC P0456
A08-014.pdf – ’07 & ’08 hybrid - Harsh Transmission Engagement After Auto Idle Stop
A08-015.pdf – ’06 SI all - 2006 Civic Si: MIL Comes On With DTC P0420
A08-020.pdf – ’06 thru ’08 ALL - Transmission Grinds When Shifting Into 3rd Gear, Pops Out of 3rd Gear, or Is Hard to Shift Into 3rd Gear
A08-023.pdf- 06-08- Sunvisor Comes Apart or Splits When Moved
Mileage
January 2006
*Interesting: Skip Shifting is Brutal on Synchronizers.
*2004-2006 Civics: Seven New DTCs Replace Outdated DTCs.
*2001-2005 Civics: Gurgling From Heater Core Accelerating Thru 1,400 RPM.
February 2006
*2006 Civic Si: Check Tire Model Before Swapping Known-Goods.
*2003 Civic Hybrid: Dead 12-Volt Battery? Replace A/C Clutch Relay.
*2006 Civic Coupe: SRS Indicator On w/ SRS Errors.
*2006 Civic Coupe: Trunk Won't Open w/ Release Lever or Remote.
*2006 Civics: Navi Voice Command Problems? Check This Out.
March 2006
*2006 Civics: Got EVAP Canister Vent Shut Valve Close Malfunction? Check EVAP System Vent Blockage.
*2006 Civics: New A/F Sensor Socket for 2006 Civics.
[B]*2001-2005 Civics: Accessory Power Socket Fuse Keeps Blowing.
*2003-2005 Civic Hybrids: Accessory Power Socket Fuse Keeps Blowing.
*2006 Civics & Hybrids: Accessory Power Socket Fuse Keeps Blowing.
April 2006
*2004-2006 Civics: Diagnosing EVAP System Leakage? Use TID Info to Pinpoint Problem.
*2006 Civics: Honda Music Link Won't Work After Installation.
*2006 Civics: Unplugging iPod From the Honda Music Link Harness.
*2006 Civics: Reinstalling the Passenger's Dashboard Under Cover in a Civic.
*2003-2005 Civic Hybrid: Always Transfer Sensor Ring When Replacing Flywheel.
*2006 Civics: Engine Won't Start?
May 2006
*2006 Civic: Noticeable Ticking Through Audio System Speakers.
*2006 Civic: Replace Seat Frame After Side Airbag Deployment.
*2006 Civic Sedan: Tick or Rattle from Right Front Going Over Bumps.
*2000-2005 Civic HX: CVT Grinds, Whines, Won't Move in Any Gear.
*2003-2005 Civic Hybrid CVT: CVT Grinds, Whines, Won't Move in Any Gear.
*2006 Civics/Hybrids: ECM/PCM Replacement.
*2006 Civic Sedans: Wind Noise from Left Power Mirror While Driving.
June 2006
*2006 Civics: Radio Changes Volume By Itself or Fades In and Out.
*2006 Civics: Speedometer and Odometer Read Higher Than Expected.
July 2006
*2006 Civic Hybrids: Brake System Indicator On.
*2003-2005 Civic Hybrid: Crackling From Right Front Accelerating or Turning Left.
*2002-2006 Civic Si: Clutch Judder After Short Block or Crankshaft Repair.
August 2006
*2006-2007 Civics: Navigation System DVD Handling Tips.
*2001-2006 Civics: Accessory Power Socket Keeps blowing Fuse.
*2003-2006 Civics: Re-Keying Sidewinder-Type Lock Cylinders.
*2001-2006 Civics: Engine Cranks But Doesn't Start/Immobilizer Light Blinks.
*2006 Civic Sedan: Center Console Gets Hot w/ Heater Running.
September 2006
*2006-2007 Civics: How to Force-Retrieve Maintenance Item Codes.
*2006 Civic Hybrid: Auto Idle Stop Doesn't Work After PCM Replacement.
October 2006
*2002-2005 Civics: A/C Compressor and Condenser Fans Don't Work.
November 2006
*2006-2007 Civics: Rewriting the ODO Data to a New Gauge Control Module.
*2006-2007 Civics: releasing a Locked ODO Value After Rewriting.
*2006-2007 Civics w/ Navi: Navi System Maps Matching.
*2006-2007 Civics: Troubleshooting B-CAN and F-CAN DTCs.
*2001-2005 Civics: S/M Fix (Heater Circuit Malfunction).
*2006-2007 Civics: Evaporator Temp Sensor Tests.
*2001-2005 Civics: Got SRS Errors? Replace SRS Unit.
*2003-2005 Civic Hybrid: Bad MPI Can Set IMA DTC Errors.
December 2006
*2006-2007 Civics (Non-Si): Common Errors.
*2003-2005 Civic Hybrid: Blown Fuse Causes IMA DTC Errors.
*2003-2005 Civic Hybrid: Error Fixes.
2007:
January 2007
*2006 Civics (all): Honda Music Link Stops Working.
*2007 Civic Sedans w/o Navi: Owner’s Manual Error: Audio System Welcome Message.
*2006-2008 Civics w/ Manual Transmission: Stiff Shifting? Popping Out of Gear? Replace the MTF.
*2006-2007 Civic Coupes: Windshield Wiper Squeaks While Working.
*2006-2007 Civics (all): Troubleshooting SRS Code (Rear End Collision Detected).
February 2007
*2006-2007 Civic Hybrids: Got IMA Errors? Replace Motor Rotor Position Sensor.
*2004-2007 Civics: Replace Solenoids or Replace Auto Transmission?
*2006-2007 Civic GX: Fuel Gauge Flashing? Check for Open Fuel Fill Door.
*2006 Civic Hybrids: IMA Errors After Jump Starting Dead Batteries.
*2006 Civic Hybrids: A/C COmpressors are Special for Honda Hybrids.
March 2007
*2001-2007 Civics: Electronically Retrieving Audio Unit Serial Numbers.
*2006-2007 Civics: Replacing Drive Belt Auto-Tentioner Pivot Bolt (READ This First!).
2006-2007 Civics: Interior Lights Stay on With All Doors Closed.
April 2007
*2006-2007 Civics: Troubleshooting SRS Error Codes.
*2001-2007 Civic GX: Engine Stalls in Reverse or Drive After Tranny Repair.
*2001-2005 Civic HX: Engine Stalls in Reverse or Drive After Tranny Repair.
*2003-2007 Civic Hybrids: Engine Stalls in Reverse or Drive After Tranny Repair.
May 2007
*2006-2007 Civic Si: Got High Idle or Errors? Check IAB Control Thermal Valve.
June 2007
*2006-2007 Civics: Replacing the Engine Block? Replace Coolant Separator, Too.
*1996-1998 Civic DX/LX: Malfunction Indicator Light On? Check H02S Connectors.
July 2007
*1998-2003 Civics: Got Error? Check for a Clogged Engine Air Inlet.
*2004-2007 Civics: Got Error? Check for a Clogged Engine Air Inlet.
*2006-2007 Civics: SRS Indicator Is On w/o Any Errors.
*2006-2007 Civics: Got Errors? Check for Debris in the MAF Sensor.
*2001-2005 Civics: Cruise Control Doesn't Set? Check for LED Brake Light Bulbs.
*2006-2007 Civics: Calibrating the Compass on Auto Day/Night Mirror.
*2006-2007 Civic DX: Install Accessory Floor Mats By the Numbers!
August 2007
*2006-2007 Civics: Always Charge A/C System to Max Capacity.
*2001-2005 Civics: Return Used ATF Filter Along w/ Failed A/T.
*2006-2007 Civics: Errors After Short Block Replacement.
*2006-2008 Civics: Wind Noise From Power Mirror w/ 3M Stone Guard Applied.
*2006-2008 Civics w/ SOHC Engine: Replacement Short Block Doesn't Come w/ Oil Pump.
September 2007
*2007-2008 Civics: Remember to Reset Power Window Control Unit.
October 2007
*1996-2002 Civic HX: Your CVT Start Clutch Installer Tool May Be Bad.
*1998-2005 Civic GX: Your CVT Start Clutch Installer Tool May Be Bad.
*2003-2007 Civic Hybrid: Your CVT Start Clutch Installer Tool May Be Bad.
*2003-2005 Civic Hybrids: Got Error? Check IPU Module Fan Operation.
*2006-2007 Civic Hybrids: Got Error? Check IPU Module Fan Operation.
November 2007
*2006-2008 Civics: Security System Sounds By Itself.
December 2007
*2006-2008 Civics (non-Si): Install Crankshaft Pulley Correctly to Prevent Oil Pump Damage.
2008:
January 2008
*2006-2007 Civics: Bad Electronic Throttle Control Relay.
*2006-2007 Civic Hybrids: Blown No. 61 Fuse (Bad IPU module fan).
February 2008
*2006-2008 Civics: Engine Cranks, But Won't Start.
*2006-2008 Civics w/ Navi: Navi Display Won't Switch to Night Mode w/ Headlights On.
March 2008
*2001-2005 Civics: No Cruise Control? Check for Aftermarket LED Brake Light Bulbs.
*2006-2008 Civics:Malfunction Indicator Lamp On? Check Aftermarket Air Intake.
*2006 Civics: MIL On? Check ECT Sensor 2.
*2006-2007 Civic Hybrids: MIL on? check ECT Sensor 2.
*2007 Civic Si: VSA Activation Indictor On After VSA Modulator Control Unit Repair.
April 2008
*2003-2005 Civic Hybrids: Installing Wrong Replacement ECM Can Cause Canister Purge Valve Circuit Malfunction
*2003-2005 Civic Hybrids: Replacing Flywheel? Transfer Sensor Ring and Torque to Spec
*2006-2008 Civics: Got F-CAN Malfunction? Try Swapping the ABS Modulator Control Unit
*2006-2008 Civic Si: Leaking Head Cover Gasket May Just Be Residual Oil Trail
May 2008
*2006-2008 Civics: Block Halves Leak? Check the Sealing Bolt or Rear Main Oil Seal
*2001-2005 Civic Coupe: Ceiling Light Rattles or Buzzes While Driving
*Interesting: M/T Intermittently Pops Out of 1st Gear
June 2008
*2006-2008 Civics: Which Multiple B-CAN Related DTCs Do I Troubleshoot First?
*2006-2008 Civics: AIRBAG OFF Indicator Turns On and Off With Front Seat Occupied
*2006-2008 Civics: EVAP Canister Vent Shut Value Close Malfunction? Check for Blockage in EVAP Canister Vent System
*2006-2007 Civics: Headliner Edge Sticks out of A-Pillar Trim
*2006-2008 Civic Coupe: Passenger's Door Glass Makes Noise When Moving
July 2008
*2008-2009 Civics: Use Torque Screwdriver to Tighten TPMS Valve Stem Nuts to Spec
*2006-2008 Civics: Excessive Parasitic Draw? Check If the B-CAN System is Awake
August 2008
*2006-2008 Civic Hybrid: Adding Refrigerant Oil or Leak Dye to a Honda Hybrid? Read This First
*2006-2008 Civic Coupe: SRS Indicator On After Replacing SRS Unit?
*2004-2005 Civics: Malfunction Lamp on? check for Bad Throttle Position Sensor
*2002-2005 Civic Si: Malfunction Lamp on? check for Bad Throttle Position Sensor
*2007-2008 Civics: No Communication Between HDS and VSA Modulator Control Unit
September 2008
**Nothing of Interest to Civic owners.
October 2008
*Interesting: Name That Noise From This Handy Chart (helpful for rattles)
*2006-2009 Civics: Can't Find the XM Radio ID? Just View It Electronically
*2006-2009 Civic Si: That Noise From the Drive Belt Idler Pulley May Just Be Normal
*1992-1993 Civics: SRS Indicator Still On? Check Out This Troubleshooting Procedure
November 2008
*2006-2008 Civics: Slide Bar coming Off? Replace the Slide Bar, NOT the Seat Frame
December 2008
*2008 Civic Mugen Si: Civic Mugen Si Under-Spoiler Installation Procedures on ISIS
*2008 Civic Mugen Si: Ordering Civic Mugen Si Replacement Parts and Accessories
*2006-2009 Civics: PC Card Won't Fully Insert into Card Slot? Check for Bent Terminals
2009:
January 2009
*2009 Civics: Outdated iPod Compatibility Table
*2009 Civic Hybrid: Outdated iPod Compatibility Table
*2006-2009 Civics: SRS Codes Are Strictly About the SIDE Airbags
February 2009
*2006-2009 Civic Hybrid: Got IMA Code Problems? Replace Motor Rotor Position Sensor
*2003-2009 Civic Hybrids: New IMA Motor Rotor Puller Shipped to All Dealers
*2006-2009 Civics: Moonroof Fully Closes and Then Immediately Goes to Full Tilt
March 2009
*2003-2008 Civic Hybrid: Got Battery Current Sensor Malfunction? Try This Before Troubleshooting
*2006-2009 Civic Si: Malfunction Lamp On for Knock Sensor Circuit Malfunction? Check the Knock Sensor Connector
February 2006
March 2006
April 2006
May 2006
June 2006
July 2006
August 2006
September 2006
October 2006
November 2006
December 2006
2007:
January 2007
February 2007
March 2007
April 2007
May 2007
June 2007
July 2007
August 2007
September 2007
October 2007
November 2007
December 2007
2008:
January 2008
February 2008
March 2008
April 2008
May 2008
June 2008
July 2008
August 2008
September 2008
October 2008
November 2008
December 2008
2009:
January 2009
February 2009
March 2009
Just got my 2006 Honda Civic iut of the shop with compressor, belt and oil pan repairs. Drove away and radio wouldn't work. Suddenly, this used car I bought a year ago needs a security code to turn the radio in. What?? 30 years old and no tunes in the car? How in the world would you get this code? What could have happened during the week in the shop to have caused this code activation to occur. What can I do (or they do) to fix this?
Google that ****. "Honda Radio Code" it will literally be the first result taking you to Honda's website for radio codes.
b16aej6
Feb 23, 2008 09:18 PM
cutzmansi
Apr 5, 2004 04:13 PM
