FL FS/FT 97 EX EK H22 with LSD and AC
Old Oct 16, 2012 | 03:36 PM
teamcalloway08's Avatar
Default FS/FT 97 EX EK H22 with LSD and AC
For sale or trade. 97 H22/LSD EX Ek with AC. OBD1. Cruise control, power windows, power locks, sunroof, and keyless entry
100% engine/transmission rebuild with about 3000 miles.
New:
rings
bearings
all seals
bb6 throttle cable
all gaskets
clutch
flywheel
water pump
oil pump.
oil pick up
NGK wires
axles
distributor
alternator
starter
all hoses
radiator
radiator and condensor fan
2.5 exhaust to stock accord muffler
master cylinder
clutch master cylinder
timing components
slave cylinder
battery
tires
o2 sensor.
Mods/accessories: Full Hmotors swap. M2B4 (LSD) transmission, Hasport bilet street/strip mounts, Hasport axles, Innovative AC adapter bracket, ESP alternator relocation kit (not in use), Corsport shifter bushings,ARP head studs, Braided/stainless clutch and brake lines under hood, thermal intake and throttle body gasket, Pearl white w/ gold flake valve cover, Inline4 billet spark plug cover, 3inch intake, Kidd Racing Hytech rep header wrapped with titanium heat wrap, manual rack, MSD blaster ss coil, MSD cap, DC seats, Ebay coliovers, Mishimoto condensor and radiator fans, ACT 6 puck sprung clutch, ACT prolite flywheel, Greddy timing belt, Kazien speed Balance shaft eliminator kit, Kazin speed manual tensioner, generic fender bolts, PWJDM: battery tie down, radiator support, shifter boot, egr block off, header bolts, distributor bolts, and solenoid cover.
thats all i can think of right now.
needs paint. body is in great shape. No ICE. Needs AC belt and recharge, tail ligh gasket, door lock remote, trunk false floor, headliner and sunshade are pretty shitty. only CEL is egr casue its block off. doesnt come on all the time. doesnt hinder performance. this is not some hack job swap. it has all been done right with no ghetto rigging. stock obd1 jdm h22 ecu.
motor is 100% sound. no ticks, knocks, leaks, nothing. Same as transmission. Car drives perfect. shifts perfect. Quiet due to stock exhaust. i slowly pulled an open header, high comp gsr ek hatch with bolt ons, as is.
have pictures of everything. and receipts for everything as well. not on black wheels. on steelies with stock hubcaps. ill try to have current pics up as soon as i can get home.
$4200 Obo OR trade. i was something very clean. dont care how fast it is. Open to anythign but really looking for a DA or Del Sol.
850-284-7148 Shayne
videos of the car
first test drive
...=ULMqIyoG8Yirs
racing
...hannel&list=UL
...hannel&list=UL
Old Oct 16, 2012 | 03:39 PM
Default Re: FS/FT 97 EX EK H22 with LSD and AC
Old Oct 17, 2012 | 07:52 AM
up
Old Oct 17, 2012 | 11:48 AM
up
Old Oct 17, 2012 | 01:56 PM
ej6joe's Avatar
pm'd
Old Oct 22, 2012 | 07:57 PM
up
Old Oct 25, 2012 | 02:16 PM
up
Old Oct 25, 2012 | 04:59 PM
AllMotorRP's Avatar
Like the car, ESP how u kept ac
Put some blades on it n call it a day
Bump
Davi_Vtec
Jan 6, 2012 01:40 PM
2fastek
May 19, 2009 11:08 AM
spoink
Nov 14, 2005 09:03 AM
silent dave
Feb 22, 2005 01:47 PM
