Transmission & Drivetrain Gearboxes, Differentials, Clutches
LSD Question-Problem
Old Oct 16, 2012 | 04:57 AM
alexsan's Avatar
Icon2 LSD Question-Problem
I have a (B18C1) GSR engine on my civic eg, i bought this LSD but does not work with 4.40 final drive (S80 gearbox).
Please help.
Anyone knows the reference o part number of this oem LSD
Old Oct 16, 2012 | 06:29 AM
Gearspeed-Performance's Avatar
Default Re: LSD Question-Problem
edit
Old Oct 16, 2012 | 09:30 AM
alexsan's Avatar
mmm
this oem lsd works on Y2, Y21, Y1, Y2(S4C) gearbox
any B16 engine?
tks
Old Oct 16, 2012 | 01:24 PM
edit
Old Oct 16, 2012 | 02:32 PM
Honda Bull's Avatar
Since I have never heard of a helical B16/LS LSD, I'm going to venture to say that's the OEM helical LSD which belongs to B16B, B18C, and B18C5 Type-R transmissions. And the S80 transmission you have is an LS, with a 4.266 final drive - not a 4.400 GSR. And if it is a 4.400 FD that doesn't fit that LSD, then someone swapped in a B16 4.400 final drive on you.
Old Oct 16, 2012 | 02:42 PM
parts@synchrotech's Avatar
Originally Posted by Gearspeed-Performance
You have a smaller B16 Differential, it is similar size as LS. The GSR and ITR have a bigger diff and those would match your current ring gear.
That is incorrect. Honda did not produce a helical B16A2 LSD. This is an OEM Type R LSD. As long as you have a 1 Line center 66 tooth Ring Gear, this will work. One important step...Turn the LSD over and bolt it to the correct side You will see if it fits correctly vs the bottom side. Here is a guide to help you ID the ring gear:
Old Oct 26, 2012 | 07:50 AM
alexsan's Avatar
Finally i sold my oem lsd, now i have a Quaife lsd. other GSR gearbox come with a different final drive and the oem lsd works fine. My final drive have 66 tooth ring gear with 15 countershaft, but 109.8mm diameter.
thanks for the information
da6xsi06
Oct 6, 2010 04:47 AM
twentyhurtz
Aug 9, 2009 10:21 AM
Turbo92cx
28
Jun 23, 2007 01:14 AM
SUis1
Oct 7, 2001 02:26 AM
