WISECO RING Placement
Old Oct 15, 2012 | 03:30 PM
pitbullGUY's Avatar
Default WISECO RING Placement
I've done a lot of searches but haven't found any help.
On the instructions that came with the pistons, i notice it says to place the number 1 ring and number 2 ring gaps 180 deg apart BUT on the piston pin line....??
I think most people try to avoid placing any end gaps on this center line
Where do you guys put your rings on wiseco pistons?
Old Oct 16, 2012 | 07:23 AM
blackeg's Avatar
Default Re: WISECO RING Placement
Keep the ring gaps off the thrust surfaces. I like to keep the top ring gap off one of the exhaust valve reliefs, and the 2nd ring gap next to an intake valve relief 180 from the other ring
Old Oct 21, 2012 | 08:20 PM
Muckman's Avatar
Moderator in Chief
The pin center line is ok. It's not a thrust side. Follow the ring end gap placement sheet.
Just remember the arrow pointing to "front of engine" should read #1 cylinder.
Old Oct 22, 2012 | 02:14 AM
pitbullGUY's Avatar
So the thrust surface is the piston skirt area? Reason I ask is because where I'm from we don't use that term
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
civic-steve-94
Sep 16, 2016 04:20 PM
pwr2lbs
10
Jan 20, 2005 02:39 AM
Sliced Beard
Jan 22, 2004 06:55 PM
garados
Jan 17, 2004 06:25 AM
