Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
What is this noise?
Old Oct 15, 2012 | 02:39 PM
Bruce Banner's Avatar
Default What is this noise?
Saturday Morning I got my tires rotated and balanced. Driving to the shop, everything was fine.
After the tires were rotated and balanced I got on the freeway and that's when I heard this noise.
http://yourlisten.com/channel/content/16920541/Noise
It kicks in at 50mph+ and gets louder as I go faster.
I can only guess it was related to the tire rotation.
Old Oct 16, 2012 | 08:13 PM
bryse68's Avatar
Default Re: What is this noise?
Check your front tires for abnormal wear such as cupping.
Old Oct 17, 2012 | 06:56 PM
I went back to the tire store, the guy felt all four tires. He said they were feathered and that with more miles it might wear in.
My last alignment was last yr on this car, just in case I will take it in for another alignment.
Old Oct 17, 2012 | 06:58 PM
10psiLsEf2's Avatar
Sounds like "cupped" tires. This is the result of either LACK of rotation or Struts that dont perform too well anymore,
Old Oct 18, 2012 | 06:31 PM
Struts are ok, koni yellows installed a yr ago. A while back I had bad front lower ball joints, those got replaced. I can only guess the bad wearing happened when I had the bad ball joints. The dump sounds are from going over things, the constant noise is the noise I am referring to. Normally it is quiet in the cabin, that constant whirring noise is the issue. It gets louder with higher speed.
Old Oct 21, 2012 | 09:15 AM
10psiLsEf2's Avatar
Just cause there koni yellows doesnt mean they are in good condition struts life span is cut short with lowered cars bruh.
My 2 cents
Old Oct 21, 2012 | 08:05 PM
My 2 cents
I've told a shop to inspect bushings when they did my lower ball joints a month ago, CV etc..They say it's ok. My dealer visits, they look at the suspension and say it's ok. I would think the koni are ok, otherwise they would have salivated to quote me suspension work.
However I do get the feeling that nobody is really checking the right thing, I do hear click noises when I back up while turning the wheel.
Old Oct 21, 2012 | 08:18 PM
10psiLsEf2's Avatar
A shop or DEALER wont recommend struts unless they are leaking. Or if the tech knows that the tires are cupped do to struts.
Old Nov 17, 2012 | 08:38 PM
I pushed down on the shock, pretty stiff, got back into place. They appear good.
Old Nov 18, 2012 | 07:38 AM
Cidone's Avatar
If there not directional tires cross rotate them left on right right on left. noise will be quiter if not gone. cupping can be caused by shocks but it can also be caused by alignment
Old Nov 23, 2012 | 09:03 PM
I did have an alignment done 2 weeks after the rotation.
The toe was out of spec on front and rear driver side.
Tires are continental contact DWS, so non directional. I was able to take it for longer drives lately, after a while at 80mph or so it goes away, but it eventually returns. I can only guess it is tire noise.
MMMGIRL
Aug 7, 2012 04:36 PM
SIDreamer
Feb 21, 2011 11:34 AM
ken9
Apr 25, 2009 12:48 PM
20ls01
May 7, 2007 07:14 AM
mikeunreal2
Feb 21, 2006 06:00 PM
