This girl needs advice for S2K
Old Oct 15, 2012 | 01:38 PM
HeatherNoelle's Avatar
Default This girl needs advice for S2K
My 2002 Honda S2000 is having all kinds of problems. I've had it looked at and guy said it was a misfire.. something about the 1st cylinder (I guess someone bent something) But it used to take forever to heat up, now that's fixed, the car still stutters and sounds like a lawn mower at random times, at others, it runs great. Any ideas??
-Fyi, the turbo has been removed, have no clue if it's been tuned right.. yes, another classic story of a girl buying something because it's "pretty"...
Old Oct 15, 2012 | 02:53 PM
Spunkster's Avatar
Default Re: This girl needs advice for S2K
What engine management is it using?
Old Oct 22, 2012 | 11:57 AM
I have no idea. They fitted a turbo on it.. but took it off, so I know they tweaked some things. The top of the engine says VTECH.. apart from the obvious, I dont know how to answer that question :/
Old Oct 22, 2012 | 11:58 AM
I can take photos if that helps?
Old Oct 22, 2012 | 12:00 PM
Sorry it took so long to reply. Crazy schedule.
Old Oct 22, 2012 | 12:02 PM
The drivers window doesn't roll up and the soft top has rips. I left the car sitting while I was deployed. Then had to leave it again when I moved to Egypt. So a few things have gone south on it.
Old Oct 22, 2012 | 03:12 PM
xenocron's Avatar
Sounds like you just need to take it to a place that can go over it with a fine tooth comb.
Two shops in WA State come to mind, Speedfactory or Kaizenspeed. Google them, see who is closer, and schedule an appt.
Old Oct 23, 2012 | 06:24 AM
kyden's Avatar
the f20c is known to crack retainers if you misshift. (eventually burning a valve or dropping it). it is the first thing that comes to mind regarding your missfire.
Old Oct 27, 2012 | 06:25 AM
rice a roni's Avatar
sound like you need a new car.
Posted from Honda-tech.com App for Android
mjudson
Dec 16, 2014 03:07 AM
ranta18
Honda S2000
29
Jan 7, 2010 03:06 PM
2000S2000Mike
Honda S2000
Aug 3, 2006 10:41 PM
Burke
Honda S2000
Nov 9, 2003 02:32 PM
Trellis
Honda S2000
17
Apr 2, 2003 12:39 PM
