Changing spark plugs...found a lot of oil
As the topic states. I was changing the spark plugs and found A LOT of oil around the spark plugs (what the hell is that area called?!). Background info: I am restoring a 92 DB2. B17 engine, has been sitting for at least a year. Interior is done, when I saw the oil I figured it was a leak from the valve cover gasket. As I am changing the gasket I notice there is a lot more oil than I initially thought. I tried to take some pics. There is so much oil, I cant event get a socket in there to get one of the plugs out. Any help is appreciated...
I requested a short story for a title.
when you take the valve cover off flip it upside down and you will see that there are 4 rubber seals (one for each plug). As they age they will become hard and brittle then oil will leak past them into the hole for the plugs. Clean up the area and replace them and you should be fine.
ps, im a fellow g2 owner and am jealous of your db2, looks like aztec green?
Thanks. Yes, Aztec green GSR, in HORRIBLE shape. But I hate to see her go to the yard so I am trying to restore her. Maybe you guys can give me some more help. How do I clean this area? I was just going to get a rag, shove it in there, and spin it around til it comes out clean. Is there a better way?
there are also seals at the bottom of the spark plug tubes. if you did not notice oil dripping down from up top, where the spark plug grommets are, in the valve cover, thos lower seals may have failed. in which case, cams need to come out
looks like the rubber boot(s) from the bottom of your spark plug wires has come off and is sticking to your spark plug. You'll need to use a long pick or needle nose pliers to try and pull the boot off the plug(s). You might need to replace your spark plug wires.
Pull cams? damn it, I have no idea how to do that. I didnt notive any oil at the top, all in the chambers. Well, I do not want to half *** it. Let me figure out how to pull the cams and take those out too. Maybe the gaskets are in this valve cover gasket kit I bought off ebay...
http://www.tegger.com/hondafaq/oilyplugs/index.html
Thats what i did, just shove some paper towels and soak it up wrap the spark plug socket with paper and shove it in down and back out to clean up the area, when you get most it soaked up remove the plug and clean it up more, the rest will pour on top of the pistons and burn out shortly.
I'm pretty sure the bseries engines don't have the rocker arm orings/seals
I have no freaking clue on this magic mystery seal under the cams that might leak oil into the spark plug holes. You will show me something new thats for sure!
I took the liberty to pull cams out for you compliments of me! so lets see what seals he is talking about! please show me how and where the oil will get in there and of all things why the hell should the cams come out?
I just aswered your last question!
What are you talking about!! please explain!
He is also correct on that.
Are you seriouse!
We all aswered your queastion and one guy comes and says you need to pull your cams to check onother seal. And you believe him and are gonna pull the motor appart!. do you even know how hard it is to do that?
Are you seriouse!
Are you seriouse!
Are you seriouse!
lol i did jk thats a motor i built 2 years ago, but really i was like what freaking seals!!!!
well good job and big ups to for trying to learn to work on the motor your self. Here is a start to help you refrence how to swap cams and or the proccess of removing the cams. heres a lil video to to show how to do the valve lash.
http://youtu.be/wMMgAHBGcJg
http://youtu.be/Uy_uR-UoUVQ
http://youtu.be/yv3Ed7VL59E
