My welding progress
Old Oct 15, 2012 | 11:46 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default My welding progress
Need advice/directions.
http://db.tt/ckEJGvCg
This is my attempt at learning TiG. Mind you I am holding the torch for the second time with no previous welding experience. So go easy on me
My first time, I burnt holes in the material.
Old Oct 15, 2012 | 07:00 PM
.dave's Avatar
i HAS questions ?
Default Re: My welding progress
Someone more knowledgable and experienced than myself is probably going to recommend starting on material other than tubing.
In the class I took, we started with lap joints, then fillet, outside corner, etc. We didn't even touch any tubing aside from doing a fillet weld for a tube to a flat plate. It was an intro course offered over a few weeks by a welding shop, not a full class offered at a community college/technical school.
Old Oct 15, 2012 | 07:06 PM
all_motor_mike's Avatar
easy..... clean ur metal better, more gas flow and less heat...... if thats 16 gauge i would not set the machine to any higher then ~60 amps. use 15-17cfm of gas flow and if ur not running a gas lense then look into getting the parts for one cause the gas coverage is much better with them. hope that helps.
mike
Old Oct 15, 2012 | 07:27 PM
what's a gas lens? this isn't a class, i work at a composite shop and we have all sorts of tools, it is slow lately and i am killing time by welding exhaust pipe cut-offs and anything else laying around.
thank you for the tips. the metal wasn't cleaned at all, and i dipped the tungsten but continued to weld.
i did some chrome/moly tubing welding, which went better as well. i will try aluminium tomorrow.
Old Oct 16, 2012 | 12:12 AM
this is a gas lense.....
mike
Old Oct 16, 2012 | 07:03 AM
that-guy's Avatar
clean your materials, turn up the gas a bit. what are the specs on your setup? cup size, electrode size, filler rod???
Old Oct 16, 2012 | 12:27 PM
SovXietday's Avatar
Amperage? Filler metal size?
Looks like you didn't really clean, are really hot, and not enough gas. Tube is also really tough to learn on, you're better off learning on flat plate if you can get your hands on some. Just make sure to get rid of the scale before you weld. Keep at it, it'll get better!
Old Oct 16, 2012 | 05:39 PM
began making a new seat frame for the motorcycle, 3/8" chromemoly. i'll post some photos when i find my phone.
Old Oct 16, 2012 | 06:18 PM
mafia's Avatar
If you are welding stainless or high crome metal you need to back purge it, for it not to sugar up.
Dont tig weld on galvanized metal.
Are you gapping the 2 tubes or butt welding them? (are you trying to make a full pen weld or just to weld it?)
You should try to learn how to walk the cup, you can make your welds look really slick.
Old Oct 16, 2012 | 06:39 PM
in the photo the tubes are butt welded. the chromemoly frame is cupped and beveled.
how do you walk the cup?
Old Oct 16, 2012 | 07:01 PM
mafia's Avatar
It's really rolling the cup, but people call it walking the cup. I suck at explaining but it's something I would have to show you in person. I weld for a living so you do need experiains to perfect it.
One tip, make sure your tungsten is very sharp at all times, this will help you see what your doing and the heat will be in a small area. Welding on SS don't stop or overheat a area it will suger it up. ( always move at a descent speed)
Old Oct 16, 2012 | 07:08 PM
watched some videos. i think i need to continue working on my freehand technique.
Old Oct 16, 2012 | 07:21 PM
mafia's Avatar
Yeah, just always remember to relax your hand, when I started off I was always tensing my hand, and then it would get sore. Pushing flame forward helps too.
Ussr?
Old Oct 16, 2012 | 07:58 PM
my seating position sucks, i have a lot to learn, still in my first week of learning.
Ussr?
are you referring to my coat of arms?
Old Nov 12, 2012 | 07:42 PM
mafia's Avatar
Updates?
I was messing around with this small pipe for a few days, if you "rattel" the cup you can make it look good and still fuse the inside together.
Old Nov 13, 2012 | 08:37 AM
vtechjunkie's Avatar
Torch angle is a big factor. If you are too far angled it will adversely effect the view, and access of the puddle. May also burn your filler rod prematurely. Finding a rhythm is paramount to getting good looking welds. But practice makes progress.
Old Nov 13, 2012 | 11:25 AM
Haven't been taking photos of welding. Busy modifying the bike frame. I'll snap some photos when I am done.
Tjabo
Welding / Fabrication
19
Feb 3, 2009 07:32 PM
robbbby
Nov 11, 2007 06:39 PM
rorik
10
Oct 22, 2007 08:24 AM
codenamezero
11
Feb 13, 2007 08:48 PM
1 2 NV
51
Jan 6, 2007 08:08 PM
