F20B del sol, turns over but won't start up. HELP!!!
Old Oct 14, 2012 | 07:58 PM
Carlos Peralta's Avatar
Icon6 F20B del sol, turns over but won't start up. HELP!!!
I've got a F20B Del Sol like I mentioned in my title. Earlier today I ran out of gas while on the road I tried starting it back up after it had just cut off on me, after I let it sit for a while I put gas in it and waited for a while more. I tried starting it back up and all it would do is just turn over or sometimes not even that. I checked all my fuses and oil and everything else and it all seemed to be good. I have no idea what it could be and I am in desperate need of help. Any ideas of what could be the problem????
Old Oct 15, 2012 | 09:04 AM
josephcmiller2's Avatar
Default Re: F20B del sol, turns over but won't start up. HELP!!!
Check fuel, fire, and air. Which one are you missing?
Old Oct 16, 2012 | 04:36 AM
Everything is good on it. It doesn't get spark, someone told me it could be either the coil or igniter.
Old Oct 20, 2012 | 03:55 AM
adam86's Avatar
If you ran out of gas and tried to crank the engine you could have burned the fuel Pump cuz no gaz= no lubrication in the fuel pump check your fuel pressure and you will know.
dvpham
May 7, 2019 04:42 AM
h0ust0n_del_sol
Apr 6, 2011 07:40 AM
94EG2B18
63
Aug 31, 2009 08:14 PM
Mike97LS
10
Nov 12, 2008 09:46 AM
