DOME LIGHT FUSE BLOWNLED 98 civic coupe
Old Oct 14, 2012 | 05:40 PM
Lacrossekid183's Avatar
Default DOME LIGHT FUSE BLOWNLED 98 civic coupe
What fuse do i need for a LED dome light i had a 10a and it still gets blown every time what one do i need for it not to explode?
Old Oct 14, 2012 | 05:52 PM
skuded's Avatar
Default Re: DOME LIGHT FUSE BLOWNLED 98 civic coupe
if its blowing a 10 amp fuse for an led light which shouldnt require many amps to run, i would say you have a short in the wiring somewhere, you should check your wiring first, you could use any size fuse but if it blows every time there is a problem the problem is not the fuse
Old Oct 16, 2012 | 07:25 PM
thanks i figured out it was a really bad cheap light somebody gave to me put it in another car and it did the same thing or maybe it was to powerful but i fixed it just got a new bulb
dsksrsases5
Honda Civic (2006 - 2015)
Oct 6, 2017 03:39 PM
dansaleen_04
Jul 22, 2013 11:19 AM
viva60
Nov 19, 2004 02:19 PM
guywitaDA
Apr 21, 2004 09:58 PM
