Clutchmasters Twin Disc, ID725, DSS 2.9 axles, KStune h2b Oilpan and much more!!!
Hello Folks, It has come to that day that I am actually parting out my racecar. I thought this day would never come but unfortunately it has. Here is a chance for you to pick up some quality parts for great pricing. Everything has low miles on it (between 20-30 total miles) and was kept in exceptional condition. Take a look and feel free to inquire.
p.s. I will keep this thread up to date whenever I sell something, so far stuff has been moving. Feel free to make an offer and if it works, I will get the stuff ready to ship. Thanks in advance.
**::Attention, Email is key, joone.nijjar@gmail.com:**
* ITR Shift Linkage with a BNIB Energy Suspension bushing kit included
* 4.9 Gear-X Final Drive kit for B16 trans
* Momo Monte Carlo Steering Wheel with Mugen Horn Button and NRG Quick Release as a set.
* Seat Rails & Sliders for Driver and Passenger Side, EG/DC. Used with Side Mount Seats.
* H22 Manual Timing Tension Conversion Complete
* JDM h22 Distributor wired for MSD external Coil. Includes MSD spark plug wires.
* H22 ARP head stud Kit with Lube, used
* ::Low Miles:: H22 oil pump bought brand new, Pro-Drive high pressure Oil Pump Gear installed, Kiazenspeed Balance Shaft Eliminator Kit installed.
* 1996 JDM H22a closed deck block Sleeved with Darton replacement sleeves, 89mm bore.
* Skunk2 K series 74mm TB with sensors and IAC Block off plate.
* Golden Eagle Oil Sandwich Plate
****SOLD to a Fellow H-T'er**** Thanks "DrCRX"
* H22 Carrillo Rods
* 89mm 13.5:1 CP pistons with relocated wrist pin for use with H22 rods and H23 crank. (20-30 miles tops!!!)
****SOLD to a Fellow H-T'er**** Thanks "92frostwhtdb2"
* PLX Wideband with Gauge.
* Hydro B series Clutchmasters twin disc fx700 Clutch
* DSS level 2.9 B-series axles.
****SOLD to a Fellow H-T'er**** Thanks "92siracer"
* H22 Valve Cover properly baffled and vented. Only releases pressure, not a bunch of oil...
* Custom h2b Scattershield powdercoated Silver
****SOLD to a Fellow H-T'er**** Thanks "Souler"
* Billet Aluminum coolant overflow catch can.
* MSD SS blaster coil
* MSD Digital 6 Ignition System
****SOLD to a Fellow H-T'er**** Thanks "richboy84"
* B&R Catch Can with lines
****SOLD to a Fellow H-T'er**** Thanks "H2BJON"
* Skunk2 k20 Fuel Rail with -6 fitting for fuel in
****SOLD to a Fellow H-T'er**** Thanks "MyLilCivic"
* SSR stainless steel 4-1 race header with bottom exit megaphone for an h2b with an h22 head.
****SOLD to a Fellow H-T'er**** Thanks "weedstnr"
* KStuned h2b Oilpan with pick up and dipstick, no dings/dents/damage.
****SOLD to a Fellow H-T'er**** Thanks "fliplude95"
* Blox Racing EG/DC Traction Bar
* XS FPR with -6 fittings in black.
* H to D series alternator relocator bracket with Alternator and belt
* h22 Euro-R Single Row Crank Pulley
****SOLD to a Fellow H-T'er**** Thanks "lovitalracer"
* Bogart Pro-4 wheels and tires. (car always rested on Jackstands) 4x100
Fr: 24.5x8.5x13 M&H slicks on 13x8 wheels (Back spacing clears brakes as large as Integra GSR/LS/RS/GS
Rr: 24.5x3.6x13 M&H skinnies
****SOLD****
* STR70mm B/H/D TB with sensors-
****SOLD****
* Skunk2 H22 Pro series stage 3 Camshafts**
* Skunk2 H22 Pro Series Cam Gears**
* DNR Ported h22 Cylinder head, includes SKunk2 Valve Train and Supertech Flat Valves.**
****SOLD to a Fellow H-T'er**** *Thanks
* Autometer Oil Pressure Gauge with Sender Unit, Autometer Water Temp Gauge with Sender Unit, and carbon Fiber bezel with slot for one more gauge. Fits into Radio din or Climate Control Slot on EG.
* ID725 injectors for a Honda K series engine with low miles as well.
* Skunk2 Oil Cap
* MFactory B16 LSD with bearings
Email is the key: joone.nijjar@gmail.com
* H22 Carrillo Rods
****SOLD****
****SOLD****
* Skunk2 Oil Cap
PMd
responded
PM for pricing but for the most part make an offer and if it works I will get it ready to ship. Only fair offers will be entertained. Thanks!
-Joone
responded
-Joone
