V2V clearance
I own a ported head with .5mm oversized vavles. I was thinking of getting S2 Pro2 cams with some Type S pistons. Would I have enough clearance? What do you guys think about all this?
I think your V2V will be pretty damn close with the oversized valves, may limit the amount of adjustment you have to use. Also the type-s pistons may not leave much P2V depending on the rods and crank you run.
If you stay in stock H22 specs you should be ok, I clayed with H23 crank and rods, with JDM H22 pistons, and got really close at a few spots. Pro1 cams, but the .020 thou less of rod should make it much better.
