B18 ECU by "Kensports"
I hope this is the correct forum for this.
I got my hands on a tuned ECU labeled with a badge saying "Kensports" and sealed with a hologram-sticker to prevent it from being opened (the ones used to secure credit card PIN numbers, for example). It came with a JDM B18C engine. Revlimiter is removed as well as speed governor and the map is slightly optimised.
I've searched for ages but couldn't find any information about "Kensports". Maybe someone here has got an idea where this ECU is from?
Thanks guys.
Thanks guys.
Any ecu that has a map on it with no revlimitter is likely complete garbage.
Revlimits exist for a reason.
I suggest re-mapping the ecu with a program that actually has a revlimit & is optimized for your engine setup.
Uhm, thanks for that. However, my question was if someone recognizes Kensports and not whether a deleted Revlimiter is making any sense. Additionally you should know that OBD2 ECUs aren't remapped so easily, or do you happen to own the equipment required to read OBD2 chips? Since you're apparently in business with chipped ECUs... Seriously, do you?
edit: In the opening post I forgot to mention it's a P73! Sorry.
@mtber, may I send you a private message regarding Crome?
I have never seen or heard of "kensports".
You did not specify it was an obd2 ecu or what model ecu you had on your original post.
Put the ecu on ebay & sell it to some one who likes driving around without a revlimit.
Get your self an ecu with a reputable map on it.
Concerning a private message. Sure.
