What ecu to use with type-R engine?
Old Oct 17, 2002 | 04:31 PM
charjacq's Avatar
New User
Default What ecu to use with type-R engine?
What kind of ecu could I use with a type-R engine? The guy I'm buying the engine from has a chipped P06 (92-95 DX ecu), but is selling it kinda pricey. Could I just use a P28 ecu (OBD1 and my car is currently OBD1, so that would be fine) and put in a mugen chip or something like that in?
Anybody has some info on this? Site?
Thanks
Old Oct 17, 2002 | 05:11 PM
Tbone's Avatar
Default Re: What ecu to use with type-R engine? (charjacq)
If you can afford it , go hondata.
Old Oct 17, 2002 | 08:00 PM
charjacq's Avatar
New User
Default Re: What ecu to use with type-R engine? (Tbone)
Yeah, I thought about that, but it's a bit too expensive for what I want or need...
Old Oct 17, 2002 | 08:14 PM
USDM 4G VTEC's Avatar
have Skunk2 chipp ur P28... they work good... my friends LS/VTEC its great with that ecu... gues it will work fine with a T-R also...
Old Oct 17, 2002 | 08:46 PM
Malgerus's Avatar
Default Re: What ecu to use with type-R engine? (JDM EF9)
yeah chip a P28... I hear they're the most versatile honda ECU's out there.
Old Oct 18, 2002 | 05:10 AM
Tbone's Avatar
Well , I used to run skunk ecu in my 90 hatch with my type r motor, I was running 11.4 cr with toda b's and the thing still ran rich as hell but it worked well. I ran 16 deg timming with it on 93 oct and it had any detonation. However a buddy of mine tried it on his b16 with i/h/e and he lost power on the dyno over his stock pr3 ecu in the midrange and the peak was the same. So it definaly seemed to like the modded motor better.
Old Oct 18, 2002 | 06:52 AM
incubus's Avatar
Sorry I don't know ecu codes.
A p28 is from what a crx si?
Old Oct 18, 2002 | 07:10 AM
SpeedMonkeyRacing's Avatar
Default Re: What ecu to use with type-R engine? (incubus)
sohc vtec (92~95)
Jeff-
Old Oct 18, 2002 | 08:21 AM
Blown90hatcH's Avatar
Yep, dyno proven to lose power on mildy modified or stock B16a when running a chipped Skunk P28. You can get a P28 ECu tuned with the ITR specs.
Old Oct 18, 2002 | 12:37 PM
Fishcat37's Avatar
Default Re: What ecu to use with type-R engine? (Blown90hatcH)
Well......you could convert the car to OBDII and use the ITR P73 ecu there's a guy that did that to his std.
Old Oct 18, 2002 | 12:59 PM
Tbone's Avatar
Default Re: What ecu to use with type-R engine? (Fishcat37)
Mackymcg did.
Old Oct 18, 2002 | 01:03 PM
Fishcat37's Avatar
yep......that's his name- thanx
Old Oct 18, 2002 | 01:56 PM
YumVTEC's Avatar
Mackymcg did.
SlowerThanU did the same thing in his pre-OBD 2g Integra when he put his b18c5 in it. Must have been a BITCH of a conversion to run OBD2 in that car.
Old Oct 18, 2002 | 02:52 PM
CRX7's Avatar
Default Re: What ecu to use with type-R engine? (YumVTEC)
I'm running a Pre-OBD PR3 ECU with my 1st gen B16a, and I'm planning on just staying Pre-OBD when I switch to my ITR motor. I'll just get the ECU chipped, and use the injectors and distributor, off my b16a.
DaddyKin
14
Jul 12, 2011 01:52 PM
92hatch_cx-t
Apr 14, 2007 10:59 PM
Felliph3
Oct 10, 2006 11:36 AM
civiclxb16a
Dec 12, 2004 07:34 PM
