rough b16 idle
Old Oct 13, 2012 | 10:20 AM
dannykhaos's Avatar
Icon2 rough b16 idle
setup:
b16a
overbore ctr pistons
gsr cams
blox valve springs and retainers
head and block decked
stock fuel setup
edlebrock victor x
stock tb
8lb flywheel
stock p28
Info:
so my issue is I have a bouncing idle during the day and it will stall the car when at a light or between shifts. at night it will usually idle perfectly but sometimes it acts up at night as well.
issue started when i swapped to a victor x im
sensors and manifold worked perfect on the previous owners car (buddy of mine)
only cel I have is o2 sensor
when I unplug the IACV it dies
blows smoke in vtec
engine has like 10,000 miles since full rebuild
engine bogs until 3500 rpm almost like its not getting fuel
stuff i have done:
tb has been cleaned
IACV has been cleaned
valves have been adjusted
timing is right
idle screw has been adjusted
distributor replaced
no vac leaks
spark plugs have been checked
FITV is deleted
coolant is bled
grounds are all good
any ideas before I start throwing more money at it?
my thoughts are replace:
tb/tps
fuel pump
injectors
o2 sensor
Old Oct 13, 2012 | 11:53 AM
grumblemarc's Avatar
The Grumpiest
Default Re: rough b16 idle
Stock P28.
Why?
Running a SOHC ECU on a DOHC.
Why?
Many mods with no tune?
Why?
Old Oct 13, 2012 | 12:50 PM
dannykhaos's Avatar
Old Oct 13, 2012 | 03:20 PM
The Grumpiest
Stock P28-mistake.
Major mods done to a DOHC engine that require a stock SOHC (wrong) ECU to compensate for increased air and fuel without benefit of a chipped or tuned ECU to run them properly will cause your issues. You cannot just slap these parts on and expect to make power. In fact, the opposite can and does occur. Lousy running car.
The only free thing you could do, that I can think of, is check the timing and check adjustments on the TPS.
Old Oct 13, 2012 | 05:19 PM
dannykhaos's Avatar
thanks. s300 is coming soon. ill wait till then
Old Oct 14, 2012 | 09:35 AM
dannykhaos's Avatar
so..
stock p28-problem
tps-problem
by why does it only act up during the day and not at night?
I live in AZ but its been really nice out during the day.
dannykhaos
Mar 3, 2013 01:41 PM
jameson_g
Dec 13, 2012 08:11 PM
lexruger
Aug 11, 2010 02:41 PM
ludesrv
Feb 19, 2010 07:41 PM
miniorf
Feb 9, 2006 10:48 AM
