1995 civic ex fuel gauge issue
Old Oct 12, 2012 | 07:00 PM
TruD16Z6's Avatar
Icon2 1995 civic ex fuel gauge issue
my gas gauge is really off and i cant figure out why...it says empty most of the time...the only time it really moves is when its completely full it says half a tank but once i get close to half a tank it reads empty...im not good with wiring so idk wat the issue is...need some pointers on how to diagnose and fix this situation
Old Oct 17, 2012 | 08:52 PM
TruD16Z6's Avatar
Default Re: 1995 civic ex fuel gauge issue
could it be that my fuel sending unit is bad?
Old Oct 17, 2012 | 10:59 PM
egsleepercivic's Avatar
its either the gauge or the sending unit, you should be able to test the sending unit with a multimeter, you will need to find the specs though
Old Oct 18, 2012 | 03:05 AM
NVturbo's Avatar
O.G. triple O.G.
the fuel gauge RARELY goes bad. It's your fuel sending unit. Swap it out with another "working" unit. Might as well replace the fuel pump with a WALBRO 255LPH while you're at it.
StrikerX
15
Jan 10, 2022 05:45 PM
Brosseau
Honda CR-V & Element
Jul 26, 2018 03:15 PM
90lsteg
Apr 1, 2004 12:06 PM
wannakno
Jun 27, 2003 08:20 AM
