97 coupe y8 - Misfire on every cylinder
Old Oct 12, 2012 | 04:18 PM
mholland45's Avatar
Default 97 coupe y8 - Misfire on every cylinder
97 coupe y8. Misfire on every cylinder change the plugs and its fine for a week or so then starts acting up again. Changed dizzy cap button but didnt help. Im at a loss.
Old Oct 12, 2012 | 04:24 PM
Former User's Avatar
Default Re: someone help!
Please create a thread title that summarizes your technical problem/question so that members may quickly understand the topic without reading your post. This helps you to get more and better responses by letting our members know what technical information that you need -- Title edited.
Old Oct 12, 2012 | 06:52 PM
crawfo661's Avatar
Default Re: 97 coupe y8 - Misfire on every cylinder
You are fouling your plugs out either by burning oil or running too rich. If its due to oil you can either replace your rings and valve guide seals or there are people that make cheap inserts to pull your plug end farther from the combustion chamber reducing there exposure to the oil. If you are running rich, it is probably because someone "tuned" the car crappy. Good luck
rex89sir2
May 23, 2013 01:03 AM
89prelude069
Sep 23, 2010 01:27 PM
dohc4life
Aug 30, 2010 08:49 PM
Ryan97
Aug 17, 2007 07:16 PM
