97 coupe y8 - Misfire on every cylinder
Old 10-12-2012, 04:18 PM
mholland45's Avatar
Default 97 coupe y8 - Misfire on every cylinder
97 coupe y8. Misfire on every cylinder change the plugs and its fine for a week or so then starts acting up again. Changed dizzy cap button but didnt help. Im at a loss.
Old 10-12-2012, 04:24 PM
Former User's Avatar
Default Re: someone help!
Please create a thread title that summarizes your technical problem/question so that members may quickly understand the topic without reading your post. This helps you to get more and better responses by letting our members know what technical information that you need -- Title edited.
Old 10-12-2012, 06:52 PM
crawfo661's Avatar
Default Re: 97 coupe y8 - Misfire on every cylinder
You are fouling your plugs out either by burning oil or running too rich. If its due to oil you can either replace your rings and valve guide seals or there are people that make cheap inserts to pull your plug end farther from the combustion chamber reducing there exposure to the oil. If you are running rich, it is probably because someone "tuned" the car crappy. Good luck
rex89sir2
05-23-2013 01:03 AM
89prelude069
09-23-2010 01:27 PM
dohc4life
08-30-2010 08:49 PM
Ryan97
08-17-2007 07:16 PM
Quick Reply: 97 coupe y8 - Misfire on every cylinder
