Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 sedan civic lx p0304 misfire
Old Oct 11, 2012 | 05:08 PM
Hiphop4x4's Avatar
Default 02 sedan civic lx p0304 misfire
P0304 is the only code im getting, I've swapped coils and put in new nvg spark plugs and it's still coming back...it doesn't seem to be to bad tho because I haven't noticed the Rpms spike or drop erratically at all or even loss of power when driving fast and hard with music bumping an a/c blowing...the only thing possibly abnormal is a slight spike in vibration at idle...I just readjusted my timing belt because of a hi idling issue after changing my head gasket and everythigs running smooth except I keep gettin this damn CEL...if anyones got any idea or had similar issue drop your opinions here plz...
Old Oct 12, 2012 | 03:17 AM
lazlong's Avatar
Default Re: 02 sedan civic lx p0304 misfire
1. swap injectors
2. valve adjustment
3. compression test
Old Oct 13, 2012 | 12:57 AM
Hiphop4x4's Avatar
Could this missing bolt be the issue? It's got a fucked heli coil so I never was able to put on in...
Old Oct 16, 2012 | 04:34 PM
Hiphop4x4's Avatar
Sooooo...I swapped the injectors and I did a compression test that told me cylinder 4 has a loss of only 6%...light still came back with p0304...if the valve adjustment is off wouldn't I have loss of air? How would valve adjustment help the issue?
Old Oct 18, 2012 | 04:24 AM
forted's Avatar
If the exhaust valve is tight it will cause lower vacuum and a slight misfire at idle. You can check the vacuum with a gauge, it should be steady and around 20.
Old Oct 18, 2012 | 08:08 AM
ehonda220's Avatar
Try changing the coil with another cylinder and see if the misfire moves to that cylinder.
Old Oct 20, 2012 | 12:19 AM
Hiphop4x4's Avatar
I went on and just did a valve adjustment and smoothened every thing out...car runs perfect and now it's time to knock out a grinding front left brake issue...btw all of the valves where over tightened
Toxin715
Jan 11, 2017 04:57 PM
2wheelhunter
Jul 7, 2014 05:15 PM
EM1Guru
24
Jun 27, 2012 09:29 PM
mr_mbuna
Aug 12, 2003 06:33 PM
redteg1
May 7, 2002 02:30 PM
