bbk intake manifold help
Old Oct 11, 2012 | 04:07 PM
jazzRS's Avatar
Default bbk intake manifold help
ok so im putting my new bbk manifold together and ran into a couple snags. first, is my aem fuel rail w/fpr will not clear the log on the manifold. no way no how. can i some how run the fpr remote from the rail? and second is i have a s2 70mm tbody and when i went to mount it up, it does not completely cover the passage into the manifold. yes, its mounted the correct way. not sure what to do about this or if anyone has any exp with this manifold. you can see in the pic the little gap that the throttle body does not cover. i can get a pic of the fpr if its really needed. any help would be appreciated
Old Oct 11, 2012 | 04:28 PM
jazzRS's Avatar
Default Re: bbk intake manifold help
Alright I solved the fpr issue, GE makes a riser/rotate plate for it. Still pissed about the tbody
tempsohc
Jan 30, 2011 05:13 PM
ctr83
Dec 28, 2007 02:11 PM
RACEPAK
11
May 31, 2005 09:34 AM
turbonitrousgsr
Jan 24, 2004 07:01 PM
