Exedy Clutch and Flywheel for Honda/Acura at Redline360!
EXEDY Racing Flywheels are made from solid one piece billet chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel and have the possibility of separating from the flywheel.
Exedy Flywheel Honda Del Sol [Lightweight - 9.5lb] (93-97) HF01
Exedy Flywheel Honda Civic Si [Lightweight - 9.5lb] (99-00) HF01
Exedy Flywheel Acura Integra [Lightweight - 9.5lb] (90-01) HF01
Exedy Flywheel Honda Accord [Lightweight - 8.9lb] (03-07) HF02
Exedy Flywheel Acura TSX [Lightweight - 8.9lb] (04-08) HF02
Exedy Flywheel Honda Civic Si [Lightweight - 8.9lb] (02-11) HF02
Exedy Flywheel Acura RSX [Lightweight - 8.9lb] (02-06) HF02
EXEDY organic racing clutches only use premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use. Driveability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. All of our clutch discs have spring center dampers to reduce drivetrain shock.
Exedy Organic Clutch Stage 1 Honda Accord (03-07) 08806
Exedy Organic Clutch Stage 1 Honda Civic Si (02-11) 08806
Exedy Organic Clutch Stage 1 Acura TSX (04-08) 08806
Exedy Organic Clutch Stage 1 Acura RSX (02-06) 08806
Exedy Organic Clutch Stage 1 Honda Del Sol (94-97) 08800B
Exedy Organic Clutch Stage 1 Acura Integra (92-93) 08800A
Exedy Organic Clutch Stage 1 Honda Civic Si (99-00) 08800B
Exedy Organic Clutch Stage 1 Acura Integra LS/GSR/Type R (94-01) 08800B
Exedy Organic Clutch Stage 1 Acura Integra (90-91) 08804
immalooser
Oct 18, 2005 08:08 PM
