Starting problems now with swap
Old Oct 10, 2012 | 07:23 PM
hondaaccordf23's Avatar
Default Starting problems now with swap
00 Accord H23a Vtec with a chipped p28 h22 basemap
So I converted from 3 wire IAVC to 2 wire had car on not realize it(on position engine not running), blew a fuse, replaced fuse.
Now my car is throwing code 9 which is Cylinder position sensor no power to etc... Check with a DMM 335 ohms, recommend is 350-700. I am not sure if it is the sensor or the wiring. I have checked conversion harness every is good except when I wiggle the wire on B plug and I hear a click with key on the on position sometimes it trys to start which is weird to me.
Now my problem is the car is starting hard and then dying.
As the video shows
http://www.youtube.com/watch?v=DHI_X...ature=youtu.be
Old Oct 11, 2012 | 11:22 PM
holmesnmanny's Avatar
Default Re: Starting problems now with swap
Looks like it's below specs. How was the car running before you blew the fuse ? I'm just curious which fuse you blew.
Old Oct 15, 2012 | 08:19 AM
Fine a little idle issue.
The fuse that blew is label ACG S
hondaaccordf23
Oct 12, 2012 11:56 PM
Thepowderblue
May 23, 2012 02:30 PM
civiccoupe94
Sep 19, 2008 01:27 PM
ppfalcon
Dec 11, 2005 01:14 PM
BLUE EH3
May 16, 2005 04:18 PM
