steering wheel shakes
Old Oct 17, 2002 | 02:52 PM
AndrewJ's Avatar
Default steering wheel shakes
My Steering wheel shakes when i hit/tap the breaks when i'm going over about 40mph... do you know what is causing this? Could it be my rotors?? nothing else shakes just the steering wheel?
also my car is at 66000 miles and the maintence required light just came on, why?
Old Oct 17, 2002 | 03:07 PM
garados's Avatar
Default Re: steering wheel shakes (AndrewJ)
The rotors are probably warped. The maintainance light doesn't mean anything. It can be reset, but you might want to do your regular stuff if you haven't yet: change oil, filter, and maybe the timing belt if you drive the car hard. HTH
[Modified by garados, 5:08 PM 10/17/2002]
Old Oct 17, 2002 | 04:53 PM
Fuuma0083's Avatar
Default Re: steering wheel shakes (garados)
Rotors Warped
Old Oct 17, 2002 | 05:01 PM
AndrewJ's Avatar
Default Re: steering wheel shakes (Fuuma0083)
how much do new rotors run?... and how can i till which one it is? or is it both of them?
Old Oct 17, 2002 | 06:51 PM
CNSK's Avatar
mine did the same thing, everytime i brake, my steering wheel shakes like crazy. I thought it maybe my rotors but i added a little brake fluid ( dot 3 ) just to see first and right now i brake alot better without shaking. try doing that first, if doesnt work then get some new rotors. just touch your rotor at the edge and see if its sharp, if it is then you need some new ones. If you dont wanna buy new ones just go get it resurfaced to straight out the rotors, you'll be good to go but eventually in the long run you'll need some rotors.
Old Oct 17, 2002 | 06:53 PM
sackdz's Avatar
~$25 a piece from autozone. They're just as good as stock, and have a warranty. I run them on the track.
Old Oct 17, 2002 | 08:24 PM
Q-OnE's Avatar
Default Re: steering wheel shakes (sackdz)
since you're on the verge of buying new rotors go get some brembo crossed drilled and slotted. a pair of front ones go for like $90-120. if you're so cal hit me up. i'll help you get a set.
Old Oct 18, 2002 | 12:43 AM
ravinR68's Avatar
i say get some brembo ones....jus put some in my bro car n the are pretty good
Old Oct 18, 2002 | 03:05 AM
WhoNeedsVtec's Avatar
Default Re: steering wheel shakes (ravinR68)
just get brembo blanks..you dont need slotted or x-drilled...hell even the 25 from autozone will work
Old Oct 18, 2002 | 03:29 AM
WiggiE's Avatar
New User
Default Re: steering wheel shakes (DrMartin)
Can you explain this??? How would the rotor's edge being sharp have to do anything to do with warped rotors?
Old Oct 18, 2002 | 04:06 AM
hondamanwill's Avatar
just remember that if you over tighten your lugs this will warp the rotors.
Old Oct 18, 2002 | 04:30 AM
comptechgsr's Avatar
Default Re: steering wheel shakes (hondamanwill)
Old Oct 18, 2002 | 05:19 AM
96IntegraLS4DR's Avatar
Mild warping rotors can be resufaced.
Old Sep 24, 2004 | 04:21 AM
luv2cruz's Avatar
Default Re: steering wheel shakes (96IntegraLS4DR)
I had the same problem so I changed all four rotors, pads and passenger side axle. When the mechanic test drove the car, the shaking got worse. We smelt and saw smoke coming from one of the brakes. This problem ended up being a bad caliper. Get your entire brake system checked out ASAP. Your life is more important than a piece of metal!
Hopefully this can help you out.
Old Sep 25, 2004 | 04:31 PM
Vtec-IsMyAntiDrug's Avatar
Default Re: steering wheel shakes (luv2cruz)
my friend had the same problem.. he bought all new rotors and the shaking went away
Old Sep 25, 2004 | 06:05 PM
spog's Avatar
sometimes your wheel will shake if your tires are not properly balanced
Old Sep 25, 2004 | 07:03 PM
Mattyg2's Avatar
Default Re: steering wheel shakes (slow99gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow99gsr &raquo;</TD></TR><TR><TD CLASS="quote">sometimes your wheel will shake if your tires are not properly balanced</TD></TR></TABLE>
thats correct after rotating my back tires to front my car shaked after 55ish then i got them balanced and it went away, brakes are warped only if you stop and it shakes, if car shakes when your going about 55ish and above you need to balance your tires
Old Sep 25, 2004 | 08:25 PM
gearkraft's Avatar
i have to mention once again, i work at a brake/muffler shop...the shaking is most likely (as mentioned before) the rotors being warped. overtightening studs does not cause the rotors to get warped, that is a silly misconception. if you have a loose lug while the others are snug, that will cause the rotating assembly to become unbalanced and eventually might warp the rotor. You would have to drive a long time like this for it to become a factor. If the pulse is pretty bad, you are better off getting new rotors as apposed to getting them resurfaced. Slotted rotors are your best bet if you plan on road racing some, but for general all purpose a good blank will be adequate. What ever you do..STAY AWAY FROM DRILLED ROTORS!! I emphasize this because i cant tell you how many kids come in with cracked rotors. the drilling process weakens the integrity of the rotor. hope this helped
d4rk13l4de
Feb 26, 2009 08:03 PM
erck
Jun 8, 2007 07:34 PM
jpopvriens
Jun 2, 2007 12:40 PM
teletekman
May 3, 2006 09:15 AM
jonnybravo
Jun 19, 2002 08:34 PM
