Whining noise when pressing gas pedal
Old Oct 9, 2012 | 09:05 PM
Mr2Rotor's Avatar
Default Whining noise when pressing gas pedal
Ok lately I have been hearing this loud whining noise when I press my gas pedal a certain amount. It seems only when I press it half way. Any less or any more and the sound is gone. I'm thinking tranny maybe?
It's a 98 civic with GSR swap and GSR tranny.
Old Oct 9, 2012 | 09:20 PM
CO671's Avatar
Default Re: Whining noise when pressing gas pedal
Where is the sound coming from, it could be from anything. Does it only happen while driving? Does it happen when on idle?
Old Oct 9, 2012 | 09:23 PM
Mr2Rotor's Avatar
Only happens when driving forgot to mention it doesn't make the sound when reving at idle
Old Oct 10, 2012 | 02:29 PM
strategy400's Avatar
Gears are whining? Maybe your bearings are getting worn and the gears are starting to mesh funny. Could be the differential.
Old Oct 10, 2012 | 04:56 PM
freshgear's Avatar
check timing-belt tension.
Old Oct 10, 2012 | 05:10 PM
Mr2Rotor's Avatar
The timing belt can whine? I didn't know that
Old Oct 10, 2012 | 05:17 PM
freshgear's Avatar
is not the timing belt. it is the tension on the belt. if the tension to big it pulls the camshaft to much. have u recently replace timing belt or waterpump check it!!!!!
Old Oct 11, 2012 | 09:44 AM
Mr2Rotor's Avatar
Yes the timing belt was recently changed last month
Old Oct 11, 2012 | 12:34 PM
13g-crx's Avatar
The whining I heard under hard acceleration was coming from the passenger seat. I fixed it by dropping my wife off at the house.
Old Oct 11, 2012 | 12:36 PM
BLKdelSol95's Avatar
nice 13g...mr2, you have a cold air intake on the civic?
Old Oct 11, 2012 | 01:34 PM
Mr2Rotor's Avatar
13g? And no I have a short ram intake.
Old Oct 13, 2012 | 10:32 AM
having a cold air intake or even the short ram you have will pull the air harder than the factory airbox or intake, causing a whistle sound when the air goes past the throttle plate when you press the pedal about 50% down... with the car running, listen for a whistle sound whenever you crack the throttle by hand... ust a theory but that could be what youre hearing
Old Oct 13, 2012 | 11:03 AM
V.MoMO's Avatar
this!
i have this very same sound on my car. stock d16y7 and i modded the stock intake a little and now i get that "whine" sound with my pedal halfway and usually around 2.5-3k rpms. nothing to worry about really and now i have grown to like it
Old Oct 13, 2012 | 11:26 AM
yea so no need to spend any money on parts that dont need replaced
All_JDM_Si
10
Oct 9, 2003 03:30 AM
BnEiAkUiTcY
15
May 30, 2002 09:34 AM
eh-D
Jan 1, 2002 04:18 PM
quickLSt
Sep 12, 2001 06:29 AM
