how to hold cam gears while timing
Old Oct 9, 2012 | 07:44 PM
9honda5civic's Avatar
Default how to hold cam gears while timing
this may be a dumb question but how do you hold the cam gears while timing my engine (b16a) do i set the cam gears then tighten the caps holding the cams in place?
Old Oct 9, 2012 | 07:51 PM
Default Re: how to hold cam gears while timing
i want to know the right way cause i dont the correct tool and i was wondering if there is another way to do it
Old Oct 9, 2012 | 09:01 PM
rc.square24's Avatar
You mean with adjustable cam gears? Loosen the cap screws on the gear, hold the cam in place with a wrench on the cam shaft hex flats to stop it from moving and also to adjust the cam advance/retard while the gear is loose. Tighten when done.
HTH
Old Oct 9, 2012 | 09:07 PM
ok thank you i havnt dealt with them before
Old Oct 10, 2012 | 03:21 AM
NVturbo's Avatar
O.G. triple O.G.
bolt down the camshafts, make sure the crank pulley is at the last mark (TDC) and THEN set your cam gears with the timing belt.
95gsr@530
Feb 7, 2015 09:24 AM
StraightNoChaser
May 31, 2008 04:17 PM
integlstrike1
Aug 13, 2006 07:45 AM
Brewer
Feb 2, 2005 10:48 AM
Black96Cobra
Oct 28, 2001 11:06 PM
