Honda S2000 Honda S2000
Air Pump Delete W/AEM EMS
Old Oct 9, 2012 | 05:35 PM
TopEndTuner's Avatar
Default Air Pump Delete W/AEM EMS
I'm going to be boosted on a custom setup utilizing an AEM EMS for engine management. I'm pretty certain I can delete the Air Pump from the software but how do I delete it from the engine bay? Can I just route the hoses into each other and take the pump completely out or what has everyone else done? Again sorry for bringing this up as I know I've seen it covered but I can't for the life of me find it
Old Oct 9, 2012 | 07:13 PM
Kaleko's Avatar
Default Re: Air Pump Delete W/AEM EMS
Do a search on S2Ki or maybe even here, they actually sell "Air Pump delete kits." I'm certain it also has nothing to do with your EMS.
Old Oct 9, 2012 | 07:54 PM
In case anyone stumbles across this an is in need I got this from S2ki.com
These are the steps from Izze:
Overall, it's quite easy. The air pump itself is located behind the front bumper, driver side corner. It's best if you remove the front bumper, or you can remove the front driver side fender liner (more difficult IMO). Remove the air pump and the large relay attached to it.
There are two hoses leading to the pump, ones hose goes from the air filter neck to the air pump inlet, the other hose goes from the air injection valve (located near the intake manifold and fire wall, it has the hose going into it and a small vacuum hose) to the air pump outlet. These hoses can be removed. It can be a little tricky removing some of the bolts but the process is self explanatory. Be sure to cap off the air filter neck with the supplied vinyl cap (the big one).
Next, you can remove the vacuum solenoid (attached to the rear corner of the air box), its associated vacuum hoses (small diameter), and the reservoir (located below the rear of the air box). The vacuum line do go under the intake manifold and attach to some "solid" lines, all of which can be removed. Be sure to cap off the vacuum hose inlet on the intake manifold with the supplied vinyl cap.
Finally, the current sensor is a black box located under the front driver side fender liner (you have to remove the entire fender liner), in the upper right hand corner. It can be removed too.
See the instructions for pictures of all these parts, which will help when your removing them. As I state in the instructions, you don't need to remove any or all of these parts with the simulator installed. For example, you can choose to leave the current sensor alone, the simulator will still work properly
If you want to remove the valve on the intake manifold, get the blockoff plate from puddymod.
The instructions on the Izze racing website have pics of everything if you need them.
Old Oct 11, 2012 | 09:36 AM
Justin Milos's Avatar
any benefits to deleting the air pump?
Old Oct 11, 2012 | 12:51 PM
Weight reduction or if you're in my boat intercooler piping clearance
boosted03
Oct 24, 2015 08:16 PM
k9n
Honda S2000
May 26, 2010 10:28 AM
trepteg
Honda S2000
Aug 24, 2009 12:36 PM
ma_rio44
Honda S2000
Nov 5, 2008 06:32 PM
AKS2K
Honda S2000
18
Nov 9, 2004 10:14 PM
