going to be raining soon in cali
Old Oct 9, 2012 | 04:18 PM
b20bFourDoorCivicLX's Avatar
Default going to be raining soon in cali
raining season is here so i need to take care of a few things 1st my passanger side leaks water from under dash,..... ok first off i noticed the rubber along the wind shield is falling off , or is off... 2nd the trunk leaks bad alot of water, i dont kno where that leaks coming from ,
can some one recommend me to a local L.A shop ive looked on google no luck...
3rd also after i got my 5-spd swap the dude gave me back my car with the de-froster disconnected it doesnt work/light up nothing....
Love driving in the rain, but not when my car leaks and gets foggy!!
Old Oct 9, 2012 | 08:20 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Default Re: going to be raining soon in cali
Have you tried searching your problems?
The leak from passenger side is from under the cowl.
Water in trunk can be from sunroof drain not in the drain hole and or tail light gaskets worn out.
Old Oct 10, 2012 | 03:36 PM
yea the guy i spoke to on the phone told me its a common problem, the drainage system is clogged or whatever, and the trunk my tail light rubber seals or corroded but i have no tools where im staying and no time, i work and take care of my terrible 2 son,....i jus need a good local shop who can help me with this problem because it being a cosmetic problem sorta instead of a mechanic problem its harder to find someone who can help.
Old Oct 11, 2012 | 08:41 PM
guyver13's Avatar
yea i have a leak in my trunk and it rained for 30 minutes in LA today, im just too lazy to look for the culprit
Old Oct 12, 2012 | 06:43 AM
dlo253's Avatar
All u need is a socket to remove the taillights and replace the gaskets. N make sure the drain tubes aren't undone. That's literally less than 30 min total. A shop will rape you bro. The front cowl leaks takes a little more time. Just need to replace the clear grommets, and the foam piece or use silicone instead of the foam..
Old Oct 12, 2012 | 02:23 PM
i agree thanks man,
Old Oct 13, 2012 | 08:12 AM
phaphon's Avatar
look up mechanics on craigslist. or maybe someone here from la can help you out
Old Oct 14, 2012 | 09:57 AM
mediajunkie420's Avatar
you gould always just pump them full of rtv sealant
Draiga1988
Nov 17, 2012 01:29 PM
liyan1430
Honda S2000
Apr 21, 2012 02:34 PM
dnunes
Aug 28, 2011 03:50 PM
mxteam
Aug 2, 2007 02:31 AM
JdoggsGSR
Sep 2, 2001 11:34 PM
