DIY wasted spark setup
Old Oct 9, 2012 | 04:05 PM
Natural Aspirations's Avatar
Default DIY wasted spark setup
Has anyone considered trying to set up a wasted spark coilpack setup using a flip-flop circuit to trigger coil packs from the single IGN trigger? It would require using the TDC sensor to sync the correct firing order. This is all pretty simple and I'm likely leaving something out or I'm sure everyone would be doing it already.
Old Oct 9, 2012 | 05:27 PM
xenocron's Avatar
Default Re: DIY wasted spark setup
Why though? Do you see a benefit with running wasted spark?
Old Oct 9, 2012 | 05:57 PM
Coil packs remove the need for cap and rotor as wear items, increase available coil charge time, etc....
spoonhbk11
11
Jun 9, 2019 07:03 PM
afnan
Apr 24, 2014 02:45 AM
EGLUVN
May 17, 2007 12:53 PM
gottagofaster
Oct 22, 2005 04:50 PM
ripthesystem
Sep 13, 2003 09:18 AM
