1991 civic HB, replaced cv axle, grinding noise.
Old Oct 8, 2012 | 06:13 PM
BlueHatch91's Avatar
Default 1991 civic HB, replaced cv axle, grinding noise.
I replaced the front passenger cv axle in my hatch, I've done cv axles before so everything went smooth. When I cut the wheels all the way, there is almost a grinding noise/feeling, did I tighten down the sway bar too tight? the cotter pin did fit in the hole just fine.
Old Oct 8, 2012 | 06:18 PM
crvtectim's Avatar
Default Re: 1991 civic HB, replaced cv axle, grinding noise.
Tire rubbing splash guard? Or you may have accidentally pushed the brake dust shield into the rotors? Though that would make noise without having to cut the wheel.
Old Oct 8, 2012 | 07:08 PM
I was thinking maybe the tire, but it didn't do it before. Is the turning radius on these cars that severe?
Old Oct 9, 2012 | 06:49 AM
crvtectim's Avatar
Is your car lowered? Are you still on stock size wheels and tires? Inspect the splash guard to make sure all clips and screws are secure.
Old Oct 12, 2012 | 08:53 AM
babyj86zc's Avatar
Prob splash gaurd.but check brakes and rotors while your down their.
ChrisTechMech
Suspension & Brakes
Jul 7, 2014 05:48 PM
iwanaturboteg
Apr 29, 2008 11:16 AM
bjones
Sep 13, 2007 09:07 AM
d16y8EL
Apr 1, 2005 04:14 PM
serious
Jul 19, 2004 11:11 AM
